Found Flyaudios Manufacturer
Old 03-07-13, 05:03 AM
  #811
Damaster32
Damaster32's Avatar
HELP PLEASE,
Started up the car this morning and got no screen, the backlights dont work either. But the radio is playing. Anyone think it might he a fuse problem??
If so where is the fuse at?
Old 03-07-13, 08:56 AM
  #812
felo2081
felo2081's Avatar
The IS has 3 fuse boxes one under the glove box, one under the steering, wheel and under the hood. I believe the one u r looking for it under the glove box if I'm not mistaking!
Old 03-07-13, 09:48 AM
  #813
RA061124
RA061124's Avatar
Originally Posted by Damaster32
HELP PLEASE,
OMG I had the same problem, the Hazard button was the only light that was working and when I pressed it, it still worked. Have you done anything to your unit (trying to fix temp/time issue?)
Old 03-07-13, 10:36 AM
  #814
Damaster32
Damaster32's Avatar
Nope, The AIR BAG right is on also in the car. The Radio CD player unit works since its OEM, but theres no screen and none of the buttons on the unit work. no light. Do you think its a fuse problem since the radio still works?
Old 03-07-13, 10:49 AM
  #815
RA061124
RA061124's Avatar
Well I fixed mine by having the car running pull the unit out and unplug and replug in each plug and then the screen came back on and lights all back. 4 days in and everything is still working. I think if your radio is working (as was mine with no screen) the fuse is still good I checked all mine several times. Try my suggestion, pull the unit out and individually unplug each connector (not all at the same time) and see if that helps.
Old 03-07-13, 06:22 PM
  #816
Damaster32
Damaster32's Avatar
thanks, will try this weekend
Old 03-08-13, 09:05 AM
  #817
4LisaJean
4LisaJean's Avatar
HELP PLEASE,
I had the same problem a month ago. Tried the easiest thing first: I unhooked the negative battery cable, waited a minute, hooked it back up, voila, everything working again. All good so far. Try that first.
Old 03-08-13, 02:44 PM
  #818
Damaster32
Damaster32's Avatar
That worked. Thanks, hope it doesn't happen all the time.
Old 03-14-13, 09:05 AM
  #819
joedr
joedr's Avatar
Has anyone installed the Flyaudio system on a Mark Levinson system?
I have found a few threads about going non-nav to nav using the OEM equipment but have not found a conclusive answer that it can or cannot be done.
My car is an IS350 2008.
Old 03-29-13, 08:25 AM
  #820
pmanliu
pmanliu's Avatar
Finally got my hands on a unit but still in shipping. Had a few quick questions hoping someone can answer:
Does anyone know how many cameras the system can support? I am running an aftermarket backup cam to an external screen, but was thinking about installing a camera on the front bumper also.
Lastly - does the backup cam only turn on when shifted to reverse, or is there an option to keep it on? Right now my backup cam is tapped into the reverse power lights, not sure if i will have to connect it to the nav's power source instead or can i leave it tapped into reverse lights?
Old 04-03-13, 06:51 PM
  #821
pmanliu
pmanliu's Avatar
Does anyone know what to do with the BLUE reverse wire in order for the back up camera to work? Does it need to be grounded or wired to a 12V source?
Old 04-04-13, 02:40 AM
  #822
felo2081
felo2081's Avatar
I can't remember the colors since its been so long since I did mine, but u have to run one to the unit, the the reverse signal one I hook it up to the actual reverse rear light and I ground it to a bolt in the trunk. The camera should come with a diagram of which color it's what!
Old 04-04-13, 06:02 AM
  #823
pmanliu
pmanliu's Avatar
Thanks for the help, hopefully to clarify, these are the 3 wires for the reverse cam. I already have an aftermarket one wired into a standalone screen, but since i have this unit now, trying to wire it to the navi screen.
  1. CCD Yellow RCA Input - Connected this to the RCA output on the camera
  2. REVERSE wire (Blue) - Not sure what to do with this? should i ground or connect to 12v?
  3. CCD + 12v wire - Not sure what to do with this either...
Old 04-05-13, 10:08 PM
  #824
pmanliu
pmanliu's Avatar
quickly whipped this out to replace the factory start up logo in case anyone else wants to do the same
*MAKE SURE YOU RENAME THE FILE TO LOGO.BMP AND OPEN IT IN PAINT AND SAVE IT AS A 24 BIT MAP IMAGE FIRST*
Old 04-07-13, 08:11 PM
  #825
TUNG
TUNG's Avatar
thank you for sharing!!!
Quick Reply: Found Flyaudios Manufacturer
