Found Flyaudios Manufacturer
Old 04-08-13, 05:28 AM
  #826
B16da9
B16da9's Avatar
Originally Posted by pmanliu
Thanks for the help, hopefully to clarify, these are the 3 wires for the reverse cam. I already have an aftermarket one wired into a standalone screen, but since i have this unit now, trying to wire it to the navi screen.
  1. CCD Yellow RCA Input - Connected this to the RCA output on the camera
  2. REVERSE wire (Blue) - Not sure what to do with this? should i ground or connect to 12v?
  3. CCD + 12v wire - Not sure what to do with this either...
That's correct
This is the signal wire that tell the unit to switch to the reverse camera input. Connect this wire to the positive on the reverse lights
This is the power source for the camera, connect the positive to the positive on the reverse lights as wire as the signal wire and the negative to the negative on the reverse lights
Old 04-08-13, 06:46 AM
  #827
pmanliu
pmanliu's Avatar
^ Thanks a bunch!
Old 04-08-13, 06:47 AM
  #828
pmanliu
pmanliu's Avatar
Originally Posted by TUNG
thank you for sharing!!!
My pleasure. Thanks for all your help with the unit and troubleshooting.
If anyone has a start up screen idea they want created, let me know your thoughts and i'll see what i can make in my free time!
Old 04-11-13, 08:37 AM
  #829
RA061124
RA061124's Avatar
Alright all those that have purchased this unit I need some help. I need an MCU update for my unit and the only way to get this is to contact the supplier, the problem is the person I have been in contact with no longer responds to my emails. Could any of you try to contact the person you purchased your unit through and see if you can get a MCU update file for your unit please? The file type is s19 or .s19. Thanks
Old 04-11-13, 08:26 PM
  #830
chi123
chi123's Avatar
Where have you guys been buying the units from? The prices I see are almost $1000 for one of these now when they use to be like $600!
Old 04-12-13, 10:59 AM
  #831
felo2081
felo2081's Avatar
Lsqbusiness.com
Old 04-13-13, 03:44 AM
  #832
felo2081
felo2081's Avatar
iPhone docking station
Old 04-15-13, 04:20 AM
  #833
eightysix
eightysix's Avatar
Default Skins / themes
Has anyone got some custom skins / themes ?
the 3 standard ones are sooo ugly
this is my startup logo if anyone wants, great quality
File Type: bmp
Old 04-15-13, 09:27 PM
  #834
knbnguyen
knbnguyen's Avatar
So I guess i'm late since i just came across this MCU update for the unit... is there one? and could anyone post it up?
Old 04-15-13, 11:17 PM
  #835
J250
J250's Avatar
quickly whipped this out to replace the factory start up logo in case anyone else wants to do the same
*MAKE SURE YOU RENAME THE FILE TO LOGO.BMP AND OPEN IT IN PAINT AND SAVE IT AS A 24 BIT MAP IMAGE FIRST*
I did exactly as what you said and also made sure it's the correct size and BIT but do you know why i'm getting this message?
Old 04-15-13, 11:38 PM
  #836
TUNG
TUNG's Avatar
Go back to ur sd card and delete the logo, since its successfully uploaded on there already. So once you delete it, it should be up
Old 04-16-13, 07:27 AM
  #837
Stavros
Stavros's Avatar
I spent some time trying to alter the original images, I agree with you they are very dated/ugly.
Unfortunately, I didn't get too far, I need to spend more time.
Nice logo by the way, thanks. I'll post some menu files during the weekend.
Old 04-16-13, 07:34 PM
  #838
J250
J250's Avatar
Still doesn't work .. I even adjusted the height to 380 and keeping 24bit but still pops up the same message
Old 04-17-13, 02:53 AM
  #839
felo2081
felo2081's Avatar
When it uploads it will say upload success. I used the pic iamnate posted in page 34.
Old 04-17-13, 06:19 AM
  #840
pmanliu
pmanliu's Avatar
Thats odd, i'm at work but will go home and double check the file. You saved it as a bitmap right instead of just renaming it bitmap?
I'll upload the file directly and hopefully that works
Quick Reply: Found Flyaudios Manufacturer
