Found Flyaudios Manufacturer
Old 07-30-13, 11:38 AM
  #1006
SlvrLEXUS
SlvrLEXUS's Avatar
Default TV tunner
Originally Posted by tenaciousF
Any updates on the TV tuner SlvrLEXUS?
Well the free tuner i received was an analog one so, i believe thats my problem. Also a digital TV is around $100 and they cant be used while driving. So I current don't have any plans of buying a Digital tuner.
Old 07-31-13, 11:04 AM
  #1007
denso1
denso1's Avatar
I was thinking about picking up one of these but trying to find the best price. I was quoted 645.00 shipped. Is this a good price?
Old 08-03-13, 10:17 AM
  #1008
pmanliu
pmanliu's Avatar
Quick question...
I'm trying to wire a camera to the "VIDEO IN" wire but the image just keeps flickering on the screen. However when i connect it to the "CCD" it works fine. I'm wondering if theres anything additional I need to do to get the "VIDEO IN" wire to work? (e.g. do i have to ground the "ILL" wire / "video cont" wires?)
Old 08-07-13, 04:57 AM
  #1009
icrash
icrash's Avatar
Smile
Originally Posted by MEAHT
But wait...it gets better.
WOW man, that's is some really great work done!!)
Any thoughts of when you finish putting the interface to such good look and share with us?))
Old 08-07-13, 01:49 PM
  #1010
MEAHT
MEAHT's Avatar
Lol thanks for the interest iCrash. I will be releasing this skin (along with others) probably this weekend. Just finishing up tweaks right now real-world testing. For example, the white menu you posted above wont make it into final design. Reason? Daytime it looks awesome, night time? Way too bright :/ Which sucks cuz my car is all white with black.
Right now my preferred menu color combo is black with grey
Ill keep you guys posted.
thanks
MEAHT
Old 08-07-13, 06:45 PM
  #1011
nosurprise
nosurprise's Avatar
That's one of the bigger problem with this unit. It's too bright at night and not bright enough during the day, and you can't adjust the brightness.
Originally Posted by pmanliu
Quick question...
The ILL wire is for illumination to be connected to the lights for the buttons, I don't think it's needed for our car and pretty sure not related to video. Video IN might be related to the TV, so maybe connect the same as to get the TV to work without the antenna.
Old 08-07-13, 08:25 PM
  #1012
booyaa63
booyaa63's Avatar
anyone know where to get a screen with a digitizer for the flyaudio unit
Old 08-07-13, 08:56 PM
  #1013
06pearlex
06pearlex's Avatar
i had to send my unit to flyaudio to get the screen repair.
Old 08-09-13, 07:16 PM
  #1014
Asher
Asher's Avatar
Default Pls help
I take my nav from my 08 and put it on 2010 and no screen no light on the bottoms any one know if thers somthing else that i need to conect ? Thers any diffrense from 2008 model to 2010 is
Old 08-09-13, 07:50 PM
  #1015
pmanliu
pmanliu's Avatar
Thanks, figured out the issue. Needed to switch the video format between NTSC/PAL then the flickering stopped
Old 08-12-13, 03:50 AM
  #1016
eightysix
eightysix's Avatar
When I connect my iphone through usb i get this error, anyone knows how to solve this?
thanks
Old 08-12-13, 07:15 PM
  #1017
booyaa63
booyaa63's Avatar
i cant even get in touch with them
Old 08-12-13, 08:40 PM
  #1018
06pearlex
06pearlex's Avatar
I called tech support at 866-325-9880. After I talked to them they gave me a RMA return number. I shipped the damage unit to Washington. I waited like 3 or 4 days and got the unit back with a brand new screen.
Old 08-28-13, 11:42 AM
  #1019
MEAHT
MEAHT's Avatar
Whats up guys. The menu redesigns are almost complete. I just need one favor. For the life of me I cant get custom background to work, even after saving in every time of BMP imaginable. Can someone send me a BMP that has worked for them? I have included links to the original and a white custom screen in case someone wants to convert them to BMP for me.
https://dl.dropboxusercontent.com/u/...s_original.jpg
https://dl.dropboxusercontent.com/u/...exus_white.jpg
By mistake I changed it (the only time it worked!) to the is-f logo which I definitely dont want seeing as how I dont own an F.
Once you send me this I can finish up the project and release the custom menus for all to use
Thanks guys
Old 09-21-13, 07:34 PM
  #1020
JC08IS250
JC08IS250's Avatar
BUMP....so I got my 30k service done today and afterwards the navi crashed and I reset it with the hidden small reset button. Well now when I press the screen it seems the calibration is off because where I press the screen is off by more than an inch. For example, I press the back button on the lower left corner and it hits the menu button 1-2 inches higher in the bluetooth menu. I did try to re-calibrate it but it still does it. =(
Has anyone experienced this issue and is there a way to truly reset this navi unit besides the hidden reset button? When I hit that button it doesn't clear any radio codes or anything. I'm thinking of unplugging the battery cable? I don't know if this is a coincidence that this happened after my 30k service or what?
Quick Reply: Found Flyaudios Manufacturer
