Found Flyaudios Manufacturer
#1098
Here you guys go:
http://www.filedropper.com/is250orange
I got lazy near the end, so it's not perfect and I cut a few corners, but they're not noticeable on the unit.
If someone wants, they can fix the CD picture file, it shows a bit of purple on the unit.
But overall, this skin makes the unit look 100000X better.
#1099
Here you guys go:
Anyway ill give it a try and thanks for sharing! Good karma is upon you
#1101
Here you guys go:
#1103
Doesn't say " Welcome Brad", that's a separate boot image.
I used photoshop, but my skills are nothing special. If you actually opened the pictures on the computer, you can see where it's a bit rough around the edges. But once it is on the unit, you can't tell.
#1106
So I did a lot of searching this weekend and was able get my rearview camera installed with the road over(Chinese flyaudio) setup....
The problem I'm having is that when I have the camera installed the nav system shows a blue screed reading CCD and when i reverse the camera turns on, but no other function works.
How do I fix this so I can use the camera and use all the other things with the nav...
Please help and thank you in advance.
#1107
You must have power going to the reverse wire on the navigation unit, so it thinks it is always in reverse, but then your camera doesn't power on until your car is in reverse.
The screen should only go to the reverse camera display when you are in reverse. I have absolutely no issues with mine.
#1108
this is correct... i didnt want to run wire from the front of the car to the back of the car so i bought a wireless camera setup... is there any way or diagram to setup a a wireless camera or should i just get a regular wired camera?
#1109
I did the same thing and bought a wireless camera set up. I then realized that the easiest place to get a signal for reverse was from the reverse bulb at the tail light. I also realized that the RCA cable that comes with the backup camera has an extra wire, exactly for this purpose. Once I saw that, I decided screw it, and ran the cable. It honestly did not take long and was not difficult. The hardest part for me was that I have a custom sub woofer box that replaced the floor boards and backing in the trunk, and it is not easy to remove.
