My car is sitting on jack stands Helpp me
I have a 2007 AWD is250, I ordered wheels for it but they shipped out the wrong offsets. Obviously , I returned them back and now I finally have the correct offsets but , I have no idea what tires to run? I have my car sitting on jackstand because I dont want to buy the wrong tires and have to spend double the money for not doing my reasearch. yes , I have searched in all the wheel threads but no one has been able to help me with a straight up answer.
wheels
Front 19x8.5 +35 I already purchased and mounted 2 tires 225/35/19 they dont rub at all.
Rear 19X9.5 +25 I have no idea what to buy because my car is awd, which means the diameter has to be close. can I buy 265/30/19 for the rear? I'm lowered on road magnets 2' drop all around . I dont mind if I have to roll my fenders.
wheels
You can use a simple tire calculator to see which tire would fit you best, for example:
http://www.miata.net/garage/tirecalc.html
I would recommend you stick with the same brand on all four tires. If you did your research already, why did you buy stagger rim sizes for your car?
recommended. I will order the tires right now , I shouldnt rub on the rear with a flat out roll correct?
Thanks
if you havent found your answer yet check this thread https://www.clublexus.com/forums/is-...thread-16.html
Thank you for the link. The reason why I asked if i can run a 265/30/19 is because everyone runing a 265/30/19 tire is using a high offset wheel. In the other hand, i want to run 265/30/19 with a
19x9.5 +25 on the rear .
CJW
02-02-15 04:45 PM
reyoasian
01-30-15 01:23 PM
