What causes lack of performance?
Old 07-24-12, 09:55 PM
  #46
chi123
chi123's Avatar
I have OEM spark plugs I bought from Sewell. They are like $70 for the set. They are pre-gapped and I torqued them to about 18 foot pounds with the engine cold. This was done when the car was at 51K, now it's at 61K. My air filter has always been clean. I've owned the car for two years and changed out air filters 5 times. Twice with the stock intake, twice with old intake, and now my new Takeda intake I installed less than a month ago. For gas, I always pump either BP or Shell 93 octane.
And yes, Kurtz, I was the one who complained about getting 12/13 MPG when I first got the car. But I started driving more like a grandma and started getting 17 MPG which is about as good as it gets I suppose. I started work at a new Acura dealer recently and they trained me at Lexus and I was in many IS's and I checked their MPG AVG display and most had 15-23 MPG.
The car simply runs fine but just doesn't feel like what it's suppose to be. I guess I'll have to dyno it now once I get my body kit installed since that's higher priority.
And for those wondering why in the world I would be racing a Matrix. I was driving to get food and some guy in a Matrix was checking out my car. We ended up lined up at a red light with a newer Mustang between us with chicks driving it. I see him slowing inching up waiting for the green so I knew he was going to take off. Surely, he did and I heard his wheels spin. So I take off and we're tied and my car is farting down the street with my loud exhaust while his car is making no noise and he begins pulling.
Old 07-24-12, 10:58 PM
  #47
chi123
chi123's Avatar
Originally Posted by chicagoblknazn
Where in Chicago are you?
Southside, by Archer and Halsted.
Old 07-24-12, 11:38 PM
  #48
509IS350
509IS350's Avatar
Have done a compression check? You might have worn/bad valves or your head basket is bad.
Old 07-24-12, 11:54 PM
  #49
panda327
panda327's Avatar
maybe something is stuck behind your accelerator
Old 07-25-12, 06:12 AM
  #50
Individual
Individual's Avatar
Since we're looking at every possibility, maybe check your throttle body and clean that out? Possibly some residue/carbon build up in the throttle body/plate that can cause the plate to stick?
Old 07-25-12, 06:49 AM
  #51
bob4256
bob4256's Avatar
I thought 350s dont have any carbon build up issues? ^^
Old 07-25-12, 06:51 AM
  #52
Duke02
Duke02's Avatar
17MPG for gentle driving isn't normal either. If I drive mine without care for gas mileage - not floored all the time but not like an old lady - I get 17 around town. if I baby it, i can usually get 21.
While the plugs come pre-gapped, given that you're having performance issues, it may be worth checking them to make sure. Looking at the plugs when you pull them could give you some hints as to the running condition of your engine.
A compression check wouldn't be a bad idea either. Nor would throwing it on a dyno with AFR readings.
Old 07-25-12, 07:17 AM
  #53
p0lo8
p0lo8's Avatar
^^ true. when i baby it I get 20-21 too.
Old 07-25-12, 07:20 AM
  #54
istarzan
istarzan's Avatar
I get 17mpg in city driving grandma style. But I get 5.5 0-60 and kill older mustang gts, camaros, and g35s. Somethings wrong with your car.
Old 07-25-12, 07:32 AM
  #55
mixa86
mixa86's Avatar
I would do a dyno test, go do a real qtr mile to see what your times are....if you see ur dyno is way low and your times really high you know you need to do some compression checks on the engine to make sure u dont got blowby.
Old 07-25-12, 07:59 AM
  #56
Individual
Individual's Avatar
They don't, I was speaking of the carbon build up in the throttle body/plate, not the valves . Most cars with higher miles/age will have carbon build up in the throttle/plate and eventually needs to be cleaned to maintain it's performance. May not be in this case, but won't hurt to check since it's behind the end of the intake tube.
Old 07-25-12, 08:53 AM
  #57
chikoo
chikoo's Avatar
OP got pwned.....if he got it preowned, it is very much possible he got a car whose engine has been swapped out to a 250
Old 07-25-12, 10:02 AM
  #58
chicagoblknazn
chicagoblknazn's Avatar
WOW!
Old 07-25-12, 10:21 AM
  #59
chi123
chi123's Avatar
A year ago, I did a compression test for a lab in Auto Tech class. I don't remember what I was doing but my car's compression in each cylinder was within 5% of each other. And some number with 160 for each cylinder. Apparently I had the highest compression of all student cars tested. And I also did another lab the same day for blowby and it passed too. Also used my car as test subject in class for exhaust leak lab, fuel test where I measured the types of gases out the exhaust, engine vacuum test, and that stuff.
The spark plugs looked about normal but the plugs closest to the firewall had a slight bit of oil on the threads.
I'm looking to do two things right now. Clean the MAF sensor and the throttle body. I noticed when I was installing my new intake, the plate wasn't "closed" properly. It was closed at an angle with the car off but don't think that's normal but I have no build-up of crap on it though. Anyone got a picture of how it looks closed?
What do you guys recommend to clean the MAF and throttle body? I heard in class some throttles have some coating on it and some cleaners can strip it off. Thanks
Old 07-25-12, 11:04 AM
  #60
knbnguyen
knbnguyen's Avatar
17MPG? man i would cry... and i drive like crazy... typically i get 20-21 mpg city driving... i get above 23-25 when i go on HWY. Something must be wrong about your car.. i have an 06 IS350 btw.
Quick Reply: What causes lack of performance?
