Wheel Spacer Question
Looking to buy some wheel spacers I want to go with 15mm all the way around and need some help from my friends here. Right now im running stock wheels and will be getting my coilovers put it on Mon. I will run stock for a lil while but then my plan is to get some Vossens on and I was wondering do I get the spacers with the nuts on them or jus the flat ones? Please help.
And what are some good brands....ive heard akata is a preerty good brand and good price
2006 RWD IS350
2006 RWD IS350
I'm planning on getting spacers soon too. From what I read, a lot of people recommend the spacers that do NOT have studs on them already. The studs can be a potential breaking part so I would get the flat ones and change out your stock studs for longer ones since you want to go 15mm. I've heard H&R and Ichibas are a popular brand with IS owners
I believe you buy extended studs from companies just like other parts. Not sure what brand though. I'm sure the more knowledgeable guys will be able to provide some better info.
I beg to differ on this. If your only doing a temp thing with stock wheels then I would get the spacers with built in studs, then you don't have to deal with the hassle of removing your stock studs in place of the extended ones. Theres plenty good brands quality spacers out there with built in studs that you can trust, like FIC, Kics, etc. The key is installing it right to make sure you don't F up your car and have the studs break on you. And for the next set of rims when you do get it, just make sure to get the right offsets. Then you don't have to worry about using spacers anymore.
Project kics spacers are quality. U dont have to buy extended studs if u get a quality spacer with built in studs. Ive read a few horror stories about ichiba but nothing about project kics. I did research across multiple boards and everyone vouched for project kics spacers. Plus they are hubcentric. I have the 10mm in classified if u wanna see what they look like.
myke441990
SC- 1st Gen (1992-2000)
13
10-05-10 10:00 PM
