Reverse side mirrors
hey guys, I was just wondering how do you set your side mirrors to go downwards so you can see the ground when you're reversing? I have the luxury package and I have seen it work before on my car, but for some reason i realized it stopped working... Do you guys know how to set it and make it stay at the spot you want it to every time you're reversing?
thanks!
thanks!
well on my car if i set in middle nothing happends, but if i set it to right or left my driver side mirror goes down but my passenger side only tilts a little bit. dont know what is going on and how to set the angel on them
i believe when its in the middle it doesnt do anything cause mine has been in the middle since i have owed it and has done nothing. try one of the sides and put it in reverse and see what happens
Yeah I've put it to one side before already, it tilts a little bit. When I tilt it down in reverse by my self it doesn't save of anything once i change it to Park or Drive it'll just go back to normal then once I switch it to reverse again it'll tilt as much as the first time, not how tilted I want it to be.
thanks!
thanks!
https://www.clublexus.com/forums/is-...ror-issue.html
https://www.clublexus.com/forums/is-...s-problem.html
It's also in your owner's manual.
Lou
I have an '07, and I find I have to do this once a month. It's frustrating--the dealer could never "replicate" the problem during the entire warranty period.
Noobs...please utilize the search function.
MKIV98TT
06-18-18 12:27 PM
