Can anyone tell me where to place axle stands on the RWD IS250 to lift the front of the car? pictures would be great.
Thanks
There's two jack points below the rocker moulding directly under the "A" pillar. I used a jack stand but you can also use an axle stand, same thing. Pictured is the left side so do the same for the right side and you should be set.
If you lift the car on that thin edge of metal like that, Will it be bended and folded flat?
We are supposed to lift the car by the base of that seam, but not on the seam itself.
The factory jack fits right into that thin edge, so it is right. I am assuming that this is not what the OP is asking for. He wants to lift the front end, so he can slide stands in those spots. Maybe I'm wrong. Try this one: https://www.clublexus.com/forums/4968419-post17.html
