How big can you go on...
Old 07-31-12, 04:25 PM
Donnf08
Donnf08's Avatar
Default How big can you go on...
How big of a rim can you go on a is250 awd... I wanna put bbs 19" 9.5 on.. Can I??
Old 07-31-12, 04:32 PM
projectdna
projectdna's Avatar
short version is "yes."
but... that's given that 1. you have the right offsets, and 2. the wheels clear the brake calipers.
Old 07-31-12, 04:34 PM
KillaIS250
KillaIS250's Avatar
What are the offsets? Are you doing 19x9.5 all around since its AWD?
May have to do a little fender work in the front, not 100% sure though....
Post up the offset and what tire size(s) you plan on running.
Old 07-31-12, 04:43 PM
Donnf08
Donnf08's Avatar
Thanks fornur help guys.. What imma do is just put some badass bbs's on instead of dropping it.. I've been seeing here if u drop a awd it starts the shakes so to eliminate that gap just go bigger.. What do u think
Old 07-31-12, 04:48 PM
KillaIS250
KillaIS250's Avatar
IMO, aftermarket wheels without a drop looks odd on the 2IS.
Old 07-31-12, 04:58 PM
RDIS250AWD
RDIS250AWD's Avatar
I agree
I had 20x8s all around before.
I got 20x9 +35 and 20x10 +40 on the way
current set up
19 x 8.5 +38F & 19 x 9.5 +45R
dropped 1.25 on Megan springs. No rub. Fenders aren't modded either.
Old 07-31-12, 05:08 PM
projectdna
projectdna's Avatar
you CAN lower the ride height of the awd 2is and NOT get drivetrain issues.
and even though you could go with larger wheels, you'll need lower-profile tires to retain oem rolling diameter, which means you won't be eliminating any of that "gap".
Old 07-31-12, 05:14 PM
RDIS250AWD
RDIS250AWD's Avatar
btw getting bigger rims will not eliminate the wheel gap, my car is dropped on springs no issues at all. I'm even running a staggered set up right now but as long as the overall diameter is the same or very close to stock you wont have any issues
Old 07-31-12, 06:06 PM
KillaIS250
KillaIS250's Avatar
ROFL @ the wheelgap quote RDIS250AWD
is250fsprt
06-21-11 08:05 AM
Mrbanhbao
10-19-10 02:32 AM
Joyride250
03-02-10 05:18 PM
mr. aristo
07-16-06 11:49 AM
Quick Reply: How big can you go on...
