2011 is350 steering failure caused accident can anyone help.
i dont quite understand the point of such lengthy post if you are not looking for legal advice... if steering failed, why are you not looking at legal advice? Why would you pay out of your own pocket if it wasnt your mistake?
I would think that accident/collision investigator would be able to find out if steering failure was due to accident or not, it seems like pretty sure thing
All of the NTHSA complaints you listed have nothing to do with your issue. Once again, I am having hard time understand why would you say you found all these issues on the internet with the steering and list those, when they clearly have nothing to do with what you explained in detail that happened to you.
So either you experienced steering failure or you didnt... if you did, contact lawer and hire investigator to determine what happened to your car.
If you are not sure if you simply lost control of the car vs some hardware failure, then it is something else.
The Lexus steering rack problems that did occur, did it make it so even though you turned the steering wheel, the steering mechanism did not move and subsequently it was impossible to steer the car?
I think you better get the report from your dealer for the steering failure ASAP.
I believe you man. Strange things like this could unfortunately happen. Glad that you are ok but I believe Insurance will take care of all your damage expenses right ?
Tech Info Resource
Pretty difficult to believe anyone would drive a car a millimeter after the steering failed. I certainly would not.
FWIW, there is nothing in the steering system associated with the electronic assist that could cause this. The rack is a standard mechanical rack and pinion with electronic boost instead of hydraulic boost. You could completely lose the power assist and still be able to steer the car without issue.
For the car to go straight despite turning the wheel, you would have to have a mechanical failure in the steering column. It would be mechanically obvious if there were a failure. The steering might be much harder if the electronics failed, but you would not lose directional control without a mechanical failure.
Also FWIW, no one on this forum has ever reported this kind of failure in the 6 years I've been a member. Ever. So, don't be surprised if we're all in disbelief - we've never seen it before, the mechanical features of this system don't typically fail as you have described, and the odds of this happening are small. Mind you, not impossible, just very small.
You need to hire an attorney who can have a forensic mechanic go over the car and determine precisely what failed. No amount of speculation from members here can help you resolve this. You need legal representation.
You are going to need a good lawyer if you really want to pursue this.
My personal opinion is that if you had issues earlier in the day with the steering, yet you continued to drive the car....you probably won't get much (if anything) by pursuing Lexus. If my car did that just ONCE, you can bet it would be a on a tow truck back to the dealership right away. I wouldn't even continue to drive it to my destination. I'm sure many others would agree with me too. There are just certain issues (steering, brakes, etc) that you just do not ignore and keep driving with. If this had happened all of a sudden, I could see a good case...but if you experienced the issue before and didn't handle it when it should have been handled (IMO) then its all up to how good your lawyer is.
I would just file the insurance claim and move on if it were me.
Strange... I remember when i had is250 i was out of gas on highway and engine shut down steering assist was off and i had no problem to pulll my car to the side, steering wheel was responding normally.
Maybe you had problem with something else? I know if your front tire pop you can lose control...just saying..
Yeah--to play devil's advocate, the "black box" only recorded the steering failure resulting from the accident, and doesn't verify your story. So, Lexus is not going to just agree with you, and take care of it on their nickel; for all they know, you are totally making all of this up, and you just were taking the curve too fast.
If you really want to pursue this, don't try and get legal advice on an owner's forum--find a lawyer.
I thought this car is not steer-by-wire. Unless you have mechanical failure of the steering mechanism, turning the steering wheel = wheels turning. And if you did have a mechanical failure, it likely wouldn't be intermittent. Something isn't adding up here.
My question is at what point of an electronic steering failure causes a CEL? If an electronic function or steering item fails in the 2IS, does that trigger a CEL? If yes, then that should have been very noticeable after the first instance of steering failure. If not, then who knows; perhaps it wasn't even electronic, maybe mechanical having to do with a suspension arm failure of some sort.
Can I just say, this is one reason why I personally perform my own modifications on my cars. I have only myself to blame if a nut/bolt is left loose on the car.
Man, I would hate to be in your shoes; but I wish you luck on your mission to uncover the truth.
