Car battery keeps dieing?
Old 08-02-12, 11:18 AM
vital
vital's Avatar
Default Car battery keeps dieing?
My battery died twice on me and I'm not sure what is the root cause. First time it died, I had to call roadside assistance for a jump and then I went to the dealership to test my battery and they said my battery is fine. It happened again this weekend and I had to get it jumped. The only thing I have in my car is a Garmin GPS but it auto powers off when engine is stopped. What could be the issue?
Old 08-02-12, 11:25 AM
Gville350
Gville350's Avatar
Could be...but how long have you been using it before this battery problem started?
edgeucated
edgeucated's Avatar
You need to give us way more information. How old is your battery? If its more than 5 years you should replace it. Get a volt meter to measure your battery, they are less than $10 at a local store.
If your battery measures less than 12.2-12.5 V with the car off, then you need a new battery.
With your car on, if your battery is less than 13-14.5 V, then you need a new alternator.
Old 08-02-12, 11:28 AM
nitrotang
nitrotang's Avatar
I think I read someone else having this problem because their car wouldn't lock or disengage the steering wheel when they open the car door. Every time you turn off your car and you get out of the car, you should hear a locking sound from your steering wheel. I believe if there's something wrong with that, where it doesn't lock the steering wheel, it drains the car battery?
Old 08-02-12, 11:36 AM
es808
es808's Avatar
Either your battery, alternator, a short in a wire or an accessory draining power. Testing the battery and alternator are easy if you have a voltmeter.
Disconnect the battery and let it sit for a couple of hours. With the voltmeter reading DC volts, check the battery. Voltage should be about 12 volts.
Reconnect the battery, start up the car and check DC voltage again. Should be about 14 volts if the alternator is working properly.
Shut down the car and let it sit again for a couple of hours. Retest the battery voltage (without starting up the car). If voltage is low, there is something draining your battery. Low voltage is around 11 volts or less.
This sounds like an intermittent problem so it may be a little more difficult to track down. Sounds like something is draining the battery if the battery is in fact ok.
Old 08-02-12, 11:38 AM
vicsis250
vicsis250's Avatar
You might want to check you alternator with a simple volt meter and did you hook up a sound system any time since the last battery died?
Old 08-02-12, 11:46 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
I would unplug the GPS and check the battery....maybe it's time to get a new one....
Old 08-02-12, 11:52 AM
shaolin
shaolin's Avatar
That's sucks.
As of now I have 140k on MY06 IS350, and so far I'm on my 2nd car battery(knock knock)... changed it last year rcvd from costco.
FYI - costco battery won't fit right but works great.
Old 08-02-12, 12:19 PM
PlacidBoi
PlacidBoi's Avatar
Since we are on the topic of batteries, I checked mine last night, and my batteries are bleeding. Is this bad? And what's the reason that it is?
Thanks
Old 08-02-12, 12:56 PM
bob4256
bob4256's Avatar
Sounds like the battery. Get it checked out
Old 08-02-12, 01:05 PM
5gears-IS
Great Deal Guru
5gears-IS's Avatar
Default Yep........
Time for a new battery I just had mine replaced with an Advance Auto Platinum battery saved $$$ using one of the discount codes below:
A123
$10 off $30 / $20 off $50 / $30 off $100 Purchase (expires 8/31/12 11:59pm)
(excludes motor oil, core charges, & promo items like oil change specials, BOGO's or 2 for 1's)
BIG30
$30 off $75 Purchase
BIG20
$20 off $75 or More
BIG50
$50 off Purchases of $200 or More
Choose in store pick up!
worker
01-29-24 08:56 AM
U8pilot
01-13-22 11:53 AM
genijet
Maintenance
10-17-08 06:46 AM
gurjot
07-01-08 04:49 PM
ted920
07-31-06 10:17 AM
Quick Reply: Car battery keeps dieing?
