Spark Plug change question
Old 08-04-12, 01:40 PM
rockyvo09
rockyvo09's Avatar
Default Spark Plug change question
Hello guys,
I have a noob question. I'm at 70K miles in my 08 IS350 and about to change my spark plugs after I noticed some symptoms of worn or wearing spark plugs (rough start and idle, sluggish acceleration, black deposits on exhaust tips). I know I was supposed to do the change at 60K, but i was caught up with school and forgot about it.
Anyways, is there any other things that I should do tune up wise with this spark plug change around this milage or anything I should know? Ill probably be buying the plugs off of sewell and following the DIY on here to change them. I recently changed the oil, cleaned my air filter and MAF sensor. Any advice would be awesome.
Thanks in advance.
Old 08-04-12, 02:01 PM
kyoso23
kyoso23's Avatar
Sounds like you did the other stuff already. Get those plugs changed, you should feel a noticeable difference. Are you using premium fuel?
Old 08-04-12, 02:11 PM
sw2oboi
sw2oboi's Avatar
cabin air filter, and brake flush if you havnt done so within the last two years.
Old 08-04-12, 02:24 PM
rockyvo09
rockyvo09's Avatar
sweet. And yes, I am using premium fuel in my car.
oh okay. Sounds good, thank you!
Old 08-04-12, 08:16 PM
4wheelin
4wheelin's Avatar
Where are you at in Okla?
Old 08-05-12, 06:23 AM
jbjones85
jbjones85's Avatar
Only other item you should do is the brake fluid as stated above. Needs to be done every 30k. As a side note if you plan on diy'ing and keeping the car for a while I would get a set of speed bleeders. Makes it a very quick and simple task.
dychang174
RC - 1st Gen (2015-present)
05-11-19 11:53 PM
ThumperPup
ES - 5th Gen (2007-2012)
03-31-15 05:37 AM
ay3333
04-13-14 04:38 PM
chi123
12-27-10 08:41 AM
AllblackLS
05-16-09 12:33 AM
Quick Reply: Spark Plug change question
