Guys that have changed out their headlights...
Old 08-07-12, 08:06 AM
B16da9
B16da9's Avatar
Originally Posted by ohiois350
if you don't have stock HID, that mean you need to buy the loaded lights from Sewell
I dont have Stock HID and I did not get a loaded version. If you're handy getting an aftermarket HID kit to work on these lights is cake.
Old 08-07-12, 08:11 AM
ohiois350
ohiois350's Avatar
yeah because you are a handy man, you could retrofit your lights, but for some people like me, need something as simple as possible, like geoxue, I think he has aftermarket HID kit, that kits could not reuse on the new headlights
Old 08-07-12, 08:20 AM
B16da9
B16da9's Avatar
He would need the item bellow to run his aftermarket ballast and then D2S bulbs. A lot cheaper then buying "The loaded" kit. Also you can find the item bellow a lot cheaper on ebay.
Old 08-07-12, 09:30 AM
BakerFX4
BakerFX4's Avatar
So the afs light will not come on or flash at all, if u pull the fuse?
Old 08-07-12, 10:05 AM
B16da9
B16da9's Avatar
Correct, but you'll also disable your Autoleveling feature by doing that.
Old 08-07-12, 11:14 AM
RDIS250AWD
RDIS250AWD's Avatar
my auto leveling still works.
Old 08-07-12, 12:15 PM
BakerFX4
BakerFX4's Avatar
Originally Posted by geoxue
the 2012 loaded set comes with HID bulbs? does it come with AFS as well? if i have an 06 250 that did not have stock HID, will AFS be supported? sorry if these are bad questions. just figured i ask! thanks!
If u dont have afs then u dont have to worry bout a light blinking and so forth whereas hid cars have to pull fuse or pull instrument cluster to hid blinking light. Lucky you. When u buy the loaded set ull get everything to install them and the relay to fix the blinker ordeal. Then just trim your bracket. Correct me if im wrong guys.
Old 08-07-12, 12:27 PM
ohiois350
ohiois350's Avatar
that right, but the thing is how is he going to cover the OEM ballasts spot?, he could buy used bulbs and ballasts for cheap, and it still OEM and down the road is may not moisture in the lights
Old 08-07-12, 12:30 PM
ohiois350
ohiois350's Avatar
No, your auto level is not working since I pulled the AFS fuse out for you
Old 08-07-12, 12:31 PM
RDIS250AWD
RDIS250AWD's Avatar
U sure??? I swear it still moves up and down when i turn the car on lol
Old 08-07-12, 12:34 PM
ohiois350
ohiois350's Avatar
wow if it is true you are lucky one Remy, mine is not move at all, please check again tonight to see it is move
Old 08-07-12, 02:28 PM
soFreshIS
soFreshIS's Avatar
Ahh I thought sewell said it was good til August. Fresh didn't u buy the loaded set baller? Hook our boy up here with ur old set
i sold them already bro like right after i ordered... i had regular halogen.. but cheap! and clean..
Old 08-08-12, 05:11 AM
B16da9
B16da9's Avatar
I'm running Infinity Ballast on mine, if you go to my retrofit thread you'll see a picture of how I closed that hole up.
I would do it myself but Photobucket is blocked at my job
Old 08-09-12, 07:49 PM
RDIS250AWD
RDIS250AWD's Avatar
https://www.clublexus.com/forums/is2...headlight.html
https://www.clublexus.com/forums/is2...wer-grill.html
Old 08-11-12, 10:53 PM
basa
basa's Avatar
I can't find any threads of how to's on installing the 2012 headlights STRIPPED..trying to find out how hard will it be to transfer bulbs and ballasts to new headlight.
Quick Reply: Guys that have changed out their headlights...
