Old 01-09-15, 03:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
DIY: Engine Air Filter and Cabin Air Filter 2008 IS250
Old 09-07-14, 08:06 PM
  #31
MikeFoxx
MikeFoxx's Avatar
Originally Posted by mdk77
Just followed this and it worked great. Well done and thanks.
My replacement air filter from Sewell had different "ribs" than the original. It still fit ok and seems to be working but not sure if anyone else has seen this.
yup my new one from them had less with more space than the old dirty one. fits the same. I still can't believe people not knowing these easy 5 min changes spend over $200 at a dealer for this to be done. It's as easy as putting a new roll of toilet paper on.
Old 09-08-14, 02:47 PM
  #32
waiman3
waiman3's Avatar
Lucky you, just found out it broken by someone long ago.
Now I stuck with it, but plan just to leave as is...
Originally Posted by Ants250
yep I broke mine years ago not knowing! Luckily I got them to cover it under warranty after some fight . Lol
Old 09-08-14, 03:23 PM
  #33
Ants350
Ants350's Avatar
Originally Posted by waiman3
Lucky you, just found out it broken by someone long ago. Now I stuck with it, but plan just to leave as is...
Yea my A/C wasn't getting cold enough because box wasn't sealing. Thank god I got it fixed.
Old 06-03-15, 02:42 PM
  #34
LexusJay
LexusJay's Avatar
Default DIY air filter engine cover instructions....
On my 2012 IS 250 that one screw on the right on the passenger side engine cover over the air filter housing doesn't seem to be just a screw. I am having trouble getting it off. The screw seems to be covered by some kind of plastic and though using a screw driver feels like it loosens the screw contained within the plastic cover it doesn't seem to come loose in away that releases the cover.
Anyone else have this experience and if so, hints about to remove or loosen the "screw" such that the engine cover can be removed?
Thanks!
Old 12-29-15, 01:09 PM
  #35
adpock
adpock's Avatar
Default How To Tuesday
Here's another helpful resource:
https://www.clublexus.com/how-tos/a/...-filter-362358
Old 08-30-16, 12:52 PM
  #36
Club Lexus Editor
CL Editor
Club Lexus Editor's Avatar
Default How-To Tuesday
Seems like perfect How-To Tuesday material...
https://www.clublexus.com/how-tos/a/...-filter-366742
Old 08-31-16, 11:03 AM
  #37
ewingli
ewingli's Avatar
do we need to leave the car on after we change it to circulation mode or can we turn the car off and then do the cabin filter swap?
Old 08-31-16, 12:01 PM
  #38
Bichon
Super Moderator
Bichon's Avatar
Set it to recirculate and then turn it off.
Pethum
07-07-17 08:51 AM
mojeko
05-11-16 03:52 PM
98023IS250
03-03-13 09:46 AM
TA-9ff
ES - 5th Gen (2007-2012)
11-04-09 09:24 AM
PCP20
04-26-08 10:11 AM
Quick Reply: DIY: Engine Air Filter and Cabin Air Filter 2008 IS250
