Tire pressure gauge
Old 08-08-12, 05:39 PM
Toxicxk23
Toxicxk23's Avatar
Default Tire pressure gauge
I have a slime tire pressure gauge and my light came on so I checked my tires. Some how my rear right tire was at about 29PSI according to my gauge. I went to an air pump at the gas station and that gauge said I was at 35PSI. Which one should I trust?
Another note, what PSI should I have my tires for good traction and MPG?
Old 08-08-12, 06:16 PM
Gville350
Gville350's Avatar
Don't trust the gas station air gauge. Get yourself a good air gauge and keep it in the glove box.
Old 08-08-12, 06:36 PM
Evitzee
Evitzee's Avatar
Get a good gauge .... I use an Autometer 2343 (about $24 from Amazon). Very accurate, very repeatable and it leaves no doubt as to what pressure is in your tire. Forget the crappy $1 or $2 pencil gauges, they are crap.
Old 08-08-12, 08:05 PM
Toxicxk23
Toxicxk23's Avatar
Yeah I figured I shouldn't trust a gas station gauge. The slime one I have was like $2.50. I'll definitely get another one. Thanks guys!
So what PSI should I be at?
Old 08-08-12, 09:21 PM
laobo979
laobo979's Avatar
Well it should be at 38 psi in the rear for the light to go if i remember rite. Just look on your driver side door for the pressure.
Old 08-08-12, 09:36 PM
rookieIS
rookieIS's Avatar
its by your door
Old 08-08-12, 10:13 PM
Shervin350
Shervin350's Avatar
thats normal, when you start driving the car the air inside the tire get hot so it shows more, the best thing is to get a portable air pump and check and fill you tires up in the morning b4 you drive on them
Old 08-08-12, 10:21 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Correct. 35psi front, 38psi rear.
Jeff
Old 08-08-12, 11:22 PM
Toxicxk23
Toxicxk23's Avatar
Jeff
I saw that and I filled them up to that but I remember reading how different pressures are better for performance and stuff.
Old 08-09-12, 12:14 AM
212LeX
212LeX's Avatar
Do you have aftermarket wheels? Maybe the tpsi are set to be different from stock wheels and tires...
Old 08-09-12, 02:00 AM
mong
mong's Avatar
35psi front and 38psi rear.
Get the digital Slime gauge.. mines works great
http://www.slime.com/shop/0-99-psi-d...-gauge-2071-a/
F_Throttle
IS F (2008-2014)
12
01-10-17 11:22 PM
NXOwner
05-19-07 01:13 PM
RA40
Wheels, Tires & Brakes Forum
12-03-04 05:44 AM
iNdoMeX
01-06-03 05:01 AM
Quick Reply: Tire pressure gauge
