Lexy left me stranded on I75
#32
It's not "so they say", it's because it has a direct-port injection system. The pump in the tank is a low-pressure supply pump for the high-pressure mechanical pump on the engine. All D4/D4S engines use the same system. Building the car with a high-pressure electrical pump in-tank (less reliable) and then having high-pressure lines running the entire length of the car instead of simply using a mechanical pump on the engine with a very short line makes little sense. Sports car or not, you need high-pressure for direct injection (approximately 2000psi), and the best way to do that is with a dual pump setup like all Toyota/Lexus/Scion D4/D4S cars have. Most DI systems from every manufacturer are similar.
The IS250 has 2 pumps, the IS350 actually has 3 fuel pumps, the direct injection low pressure supply pump (in tank), the direct injector high pressure pump (on the engine), and the port injection pump (in tank).
Jeff
Jeff
