My set is ordered (1725 dollars later). I know it says they are complete ready to bolt up. The bumper bracket underneath the light... Does it come w that modified to fit? Or will i have to cut mine or what not?
I would contact sofreshis he's the only member I know that's as baller as u to buy the loaded set. The rest of us bought the stripped. Ohiois350 is also pretty knowledgeable about the 2012 headlights he helped me install mine.
I have an 06, I had to cut the brackets to fit. Once you get it install if you want the oem drls to be off you gonna need to take it somewhere to turn them off, the LEDs will be on when u turn on your parking lights, in order for you to make it turn like the oem 2011 or 2012 then you need to cut the wire and run it to the IG2.
I think what OP wants to know is the bracket thats supposed to be modified to hold the headlights still has to be cut with the loaded set or does it come cut already
Still would need to cut very easy I may have a picture of them on laptop. But u still would cut . Very easy to do! Just so u know one screw won't line up. But still isn't a problem with figment
Or anything! Enjoy bro!
