is350 convertion headlights & Taillights
I'm new to CL- and I will be getting a 2008 is 350 in 2 weeks... So I been wanting to know where can I go to get the new type of headlights and tail lights for my 2008 IS 350... is it hard to do the convertion...is it possible... how much is it.... can some one post pictures of how they done it ... a before and after picture would be awesome..... Thanks peeps
Sewell is having a special on the 2012 headlights now til Sept. Stripped set 1200 loaded set 1800. They carry the tail lights as well. Sign up and link ur CL account for a discount
Before
After
more can be seen at this link
http://public.fotki.com/remydee/
Before
After
Before
After
Before
After
Conversion is definitely do-able. Between headlights and tailights you should be spending about $2,000 which isn't too bad for what it does to the car.
The headlights will be a direct fit, the tail lights not so much. There will be a tab that you must shave or bend out of the way for the tail lights to seat properly, its easy though. And make sure if and when you get the taillights you also get the harnesses, as the ones on your stock taillights wont work.
Welcome to CL
Welcome to CL
no the headlight came with harness, if you already have the HID lights all you have to buy the striped lights and save money on the ballasts and bulbs, but If you don't know hoe the remove the ballasts from the old lights, it is kinda pita to remove, so buy the loaded one is easy, and worry free
That's Sewell price, our CL member discount which you have to register there with your CL name and you will have any other CL member discount only on that site, and you have to use the promotion code in order to have $600 discount on MY2012 retrofit headlamp set. The code is 87LEX12, and that will expire at September 03 2012. Make sense?
