Do you need a rear camber kit to go negative camber?
Do you need a rear camber kit to go negative camber? Reason why I ask is cause my rear is pretty wide and hits the fenders sometimes. Fenders have already been shaved
Rear is size 19x10 +27 offset
tire is 245/35/19
tire is 245/35/19
This is true, but he only has 10" wide wheels.. it will be much cheaper to just buy the camber kit and go a degree negative.. I have 11" wide wheels and I need to install my camber kit even with the quarters pulled 1"
Platinum VIP did this car -8 Deg all factory arms
https://sphotos-b.xx.fbcdn.net/hphot...25470566_n.jpg
So you're saying there is enough stock adjustments to get a lot of camber?
The oem camber arm isn't adjustable. I just installed the megans today and its just bairly shorter all the way negative then the oem so it doesn't offer toooo much more negative camber. What they are talking about is having a smaller wheel you can go lower, by going lower you get natural negative camber. Those must be 18's? in the picture? If not then I don't know what the hell he did lol
