I wish my IS350 would shift at 7k + RPM!!
Man, I was just noticing how much power the IS350 has at the high RPMs... its a petty it shifts at around 6,500 rpm... I don't understand why Lexus doesn't let it rev higher? IT would make SO MUCH more power, and be so much more faster... all the power is at the higher RPMs, every time i drive my car I always wished it shifted later... like 7,000-7,200RPM sounds great to me...
Makes me wonder if they will EVER come out with a chip for the ECU... I wouldn't even want a chip to re-map the ECU, if we can just increase the revs it would make it great.!!!
OR... if the IS350 had 8 gears, and the gear ratios being shorter, that way it would stay in the higher revs rather than having longer gears...
Anyone agree with me? Or have anything to add??
Well, there is a lot of compression in our little engines, I would worry about losing a piston. You must floor your car much more often than I do
Perhaps you should get a nice Ducati so you can really hear the revs
Enjoy your ride and please be safe, my kids might be playing on that street you are driving on!
