Fluid Leak??
Use brake clean to clean off the surfaces.
Seeing you have fresh oil drips in spots it appears the leak is current and still present.
Have you ever signed up at Lexus.com and viewed your vehicle's previous service history at Lexus? That might help see what had been replaced/repaired and help narrow down where the problem is coming from.
GL!
GL!
Yep, one hell of a mess is definitely what I had. I wiped things down pretty well and now have a much better baseline to go off of. Will get back under this weekend and see what it looks like.
Is it ok to spray a degreaser like Simple Green onto those electrical connectors? I'm not going to unplug any of them, but just to get the grime off the outside of wires and connectors...is that ok or a no-no?
Yep, my lexus just shows regular maintenance and valve spring recall.
Oil level is still good and the same, so.......Guess I'll find out this weekend.
I've been checking the top side of the engine daily and it looks ok. Will get back under this weekend and see what that looks like. Hopefully, it was just a very messy repair from before, but I do have an extended warranty on it so I am good to go.
Newstart
10-19-17 01:43 PM
