Seafoam Treatment
Old 09-06-12, 03:14 PM
TTechLexus
TTechLexus's Avatar
Originally Posted by KumarBDH
Now one mroe question in the pic above do i pour it into the hose end where the finger is pointing to or the other end????
End where you can feel the suction
Old 09-06-12, 03:20 PM
Kumar350
Kumar350's Avatar
Jmo I would use the seafoam instead of the mopar product with a dodge video example. Just me being me.
Old 09-07-12, 01:42 PM
Kumar350
Kumar350's Avatar
Just poured it in and did the process now time to wait for the smoke show
Old 09-07-12, 11:14 PM
aznlonly
aznlonly's Avatar
uh funny I did seafoam for my car like 2 weeks ago..and only a little bit of smokes come out..
Old 09-08-12, 05:46 AM
ISFWes
ISFWes's Avatar
Default Seafoam
I had an idle problem a few months ago. And I used a can of the spray seafoam on my car. I just sprayed the can into the intake for about 5 minutes while someone kept the RPMs up.
Since I started using it. I havent had any issues with the idle.
Old 09-08-12, 07:52 AM
meis250
meis250's Avatar
hey ISFWes, could you be more specific on where you've sprayed the seafoam? I recently bought a spray as well and I was wondering what's the best way to use it. Thx
Old 09-08-12, 08:52 AM
Toxicxk23
Toxicxk23's Avatar
might give this a go tomorrow!
Old 09-08-12, 04:29 PM
ibidu1
ibidu1's Avatar
Its probably best to do this with the engine warm after a long drive, that way it would soften dirt and carbon. That should be better at cleaning I assume
Old 09-08-12, 05:59 PM
KillaIS250
KillaIS250's Avatar
BG44K works wonders as well!
Old 09-08-12, 07:16 PM
ISFWes
ISFWes's Avatar
Default Seafoam
I loosened up the MAF sensor between the air filter box and the throttle body. You can't remove the sensor. But you can lift it up and insert the thin plastic nozzle.
When you spray the fluid. The car starts to stall at idle. So I had someone hold the accelerator and rev the engine.
Old 09-09-12, 04:43 AM
iRyan
iRyan's Avatar
let me know if it works....then come do it on my car lol
Old 09-09-12, 07:46 AM
Toxicxk23
Toxicxk23's Avatar
If you pour it into the gas tank, will it keep smoking until that tank of gas is done?
Old 09-09-12, 08:04 AM
TTechLexus
TTechLexus's Avatar
It doesn't smoke from what you put in the gas tank
Old 09-09-12, 10:58 AM
Toxicxk23
Toxicxk23's Avatar
So whats the purpose of putting it in your gas tank? To keep it constantly cleaning?
Old 09-09-12, 01:10 PM
Kumar350
Kumar350's Avatar
It only smoked a little bit no big smoke show
Quick Reply: Seafoam Treatment
