is350 rpms out of wack when in "R" or "D"
Old 09-08-12, 03:39 PM
aznoutkast
aznoutkast's Avatar
Default is350 rpms out of wack when in "R" or "D"
it rarely happens, but when i put it into drive or reverse it feels as if the car is jerking to trying to go ahead or reverse out. any others has this ? this happens on start up btw.
Old 09-08-12, 08:54 PM
aznoutkast
aznoutkast's Avatar
48 views CL? reallY??
Old 09-08-12, 09:19 PM
Snyperifle
Snyperifle's Avatar
Well, is your car slowly moving already when you change gears?
Old 09-08-12, 10:14 PM
Sango
Sango's Avatar
Patience is a virtue and need to give time for the people who may know the time to answer. Most likely, out of those 48 views, 0 actually knew the answer; it's not a surprise. At least give 24 to 48 hours.
My guess would be, the engine is cold and would naturally rev higher so it the car feels like it wants to move. Now if the car were already warmed up, it would most likely not do this.
Old 09-08-12, 10:20 PM
Toxicxk23
Toxicxk23's Avatar
That is correct. I know exactly what you're talking about OP. I asked about this in a thread before and I got the same answer. It's just cause the car is revving higher when the engine is cold like Sango said. Just hold the brake down harder when switching into D or R and it wont jerk so hard.
Old 09-08-12, 10:31 PM
Sango
Sango's Avatar
Just to add on.
I know two other like symptoms. The first is if you're going about 40 mph/70 km/h, the car won't engage to 6th gear. The other is at those same speeds, let go of the gas and the car feels like it doesn't want to slow down as if there was cruise control for the same reason.
Once it's warm, the above symptoms also disappear.
Old 09-08-12, 10:40 PM
aznoutkast
aznoutkast's Avatar
Saaaaaaaaaank yoooooooooooooooooh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! =.).....
jz1219
04-15-16 11:45 PM
Gerb
07-07-14 06:42 PM
lx470man
IS F (2008-2014)
11-22-08 10:11 AM
ShowcarA4
03-08-06 02:54 PM
Quick Reply: is350 rpms out of wack when in "R" or "D"
