oem chrome mufflers
how do u polish it because my muffler is black
Do you only need the tips or the entire axel back exhaust? I have the OEM tips that I'll sell to you if you need them.
Plus, there's a DIY about polishing the OEM exhaust. I did it to mine and like it. Free is good. The black finish comes right off but you have to use a Scotch brite pad to remove it. Don't use sandpaper since it may be too coarse and the scratches may be too deep to get out. I used a dremel pad with the Scotch brite wheel on it. Faster and better.
PM me if you have questions.
Here's the link to the OEM exhaust polishing post:
https://www.clublexus.com/forums/is-...t-exhaust.html
There was a concern raised about the exhaust rusting if the coating is removed. I'm one of many who have actually done it and there are no signs of it rusting. I've had mine for about a year and have yet to see rusting. It should have rusted almost immediately. FYI.
And yes you can use steel wool but I found that the dremel method was a lot quicker. To each his own...
songoku
01-17-18 12:28 PM
vtecturtle
04-19-15 03:29 PM
hurricane
10-28-07 01:11 PM
