IS250 Carbon Build up CSP
Old 10-13-12, 07:44 PM
  #166
drewster12
drewster12's Avatar
Mine took about a week to order. Total turn around time from when I first brough the car in for a carbon check to when i got the pistons replaced, it was 2 weeks.
Old 10-15-12, 01:25 AM
  #167
gmanjeep
gmanjeep's Avatar
My Job Was done In 2 days, No questions asked, But I did have to pay $61.00. I am assuming it was for the oil. I know normally when I go there for an oil change they use a synthetic blend and it is about the same amount of money.
06 IS250 115,000 miles
Old 10-15-12, 08:54 AM
  #168
freeflight
freeflight's Avatar
Has any 2010 IS 250/250C owner got this letter? I haven't received it.
Old 10-15-12, 09:08 AM
  #169
rizkyk
rizkyk's Avatar
Could this carbon build up cause excessive oil consumption?? I ask cuz when I told lexus that i was losing oil, they kept replacing my pcv valve saying its clogged. 3 times over 2 years?? could it have been clogged due to the carbon build up and hence burning more oil??
Old 10-15-12, 12:28 PM
  #170
KillaIS250
KillaIS250's Avatar
Judging by the wording on the TSIB, not all 2010 owners will receive this TSIB, just the ones that had their 2010 models manufactured before they starting shipping them with the updated pistons I assume. I personally think all the IS250's should be covered because i've had carbon issues even after the updated pistons...Maybe they haven't seen enough 2010's come in (due to most of them still having low miles) for the issue?
Yes it can. Diagnostic Procedure B of the original piston replacement TSIB uses oil consumption as a diagnostic measure for the issue. I believe if you are losing 1 qt of oil or more in 1,200 miles - the piston replacement TSIB can be applied as that is a sign of the issue.
Old 10-15-12, 01:24 PM
  #171
tex2670
tex2670's Avatar
Originally Posted by diagtime
What you've described is consistent with a carbon caused misfire. not just "vibrations." no one else should take that critically......just thought i'd point out how an is250 owner would describe the condition in their own words.
some things you should know.
1. it's very interesting they are asking for diag time. you must not have another dealership near you. most dealerships would be more than happy to check out a car for free that will likely need a $7000 warranty repair. you can haggle with your dealership or just call another one and make sure they're willing to take your potentially very profitable business.
2. codes are not needed. not at all. the bottom line is, unless your check engine light actually came on, it's not likely that any codes will be stored. Some people like to check something a lot more in depth called the misfire monitor. it's complicated to explain how it works, but the bottom line is that it will store a misfire history for an extended period of time. Although this is usually looked at, it's still not needed to perform the CSP.
3. at 78k, you will have needed to have you spark plugs changed at some point (due at 60k). they will also need to be the correct kind. aftermarket shops and even toyota dealerships are notorious for installing the wrong plugs because the direct injection GR motors take different plugs than the normal GR motors. Hopefully, you will have had them replaced at a lexus dealer so the history with the spark plug part number will be available. if you replaced them yourself, the technician will need to pull one out and verify it's the right part number. there's also a certain marking on only the factory installed plugs so they can tell if it's been replaced.
If you have not had spark plugs replaced, you will need to have it done. they can install new plugs and then do they misfire duplication procedure. new plugs will not affect the chances of a true carbon caused misfire to happen. even if they couldn't duplicate it.....welll.....you were overdue for plugs anyways.
Very interesting. I just called my dealer, and they gave me the same story on the codes. First they said they had to replicate the issue, but I asked if its "intermittent" how can they replicate it? And they said that if there is misfire, there will be codes stored. There is a post on one of the previous pages where the dealer took a camera to check on the carbon build up--good advice. I might try that if they say they can't replicate the issue. I had the same experience for 4.8 years on the cam gear TSB--until they finally replicated the issue 3 months before my warranty expired.
Old 10-15-12, 02:24 PM
  #172
KillaIS250
KillaIS250's Avatar
Maybe try your luck with a different dealer too?
Old 10-15-12, 02:45 PM
  #173
jlee403
jlee403's Avatar
07is250 awd and i never got this letter o.o
Old 10-15-12, 03:38 PM
  #174
meis250
meis250's Avatar
07is250 awd in Canada, I just had the top engine clean done under warranty. I was told that there is no CSP that would apply to Canadian is250s. Strange...hope not to experience the rough idle again, I am only driving her hard occasionally.
Old 10-15-12, 05:51 PM
  #175
Road Rage
Road Rage's Avatar
my God, I have lost count of how many times I've dealt with this.
Old 10-15-12, 11:53 PM
  #176
250Lexus57
250Lexus57's Avatar
Still waiting on my letter to bought the car used from another
Dealership other then Lexus and had the short block and pistons and rings
replaced not even aweek after I had the car took them almost amonth to return my
Car I bought the car in may 2012 and its a 2009 Lexus is250 rwd with 45000 miles now
Replaced the short block at 41000 miles get shakes here and there but no rpm fluctuate
was wondering if ill receive this letter I'm from hawaii
Old 10-16-12, 05:01 AM
  #177
tex2670
tex2670's Avatar
I was thinking the same thing if they deny it.
Old 10-16-12, 02:32 PM
  #178
CNStars17
CNStars17's Avatar
I picked up my 2007 AWD IS250 last week saturday. It has 72,000 miles on it. I was jw if i am covered under this letter and how they would even know to send one to me?
Old 10-16-12, 02:39 PM
  #179
mj250
mj250's Avatar
Ive been reading through this thread for the past few days, I picked up my IS250 2 weeks ago. I have an 2006 with 57000 miles. Im encroaching on 72 months (I think that is the monthly limit, but I could be wrong) would I be covered? And I am also curious if the previous owner had it done.
Old 10-16-12, 05:44 PM
  #180
ajfinoak
ajfinoak's Avatar
Anybody have any idea how Lexus is deciding who gets the notices when? I have an 08 and had the top end cleaning 2 years ago but I would like to get a copy of this (from Lexus) to have around when the shakin' starts up again. In any case when the car hits 9 years bye- bye.
Quick Reply: IS250 Carbon Build up CSP
