IS250 Carbon Build up CSP
#886
Do you need the letter to do this maintenance? My IS experienced this a few times but it has gone away since but would still like to have this service done. The dealership wont be able to "duplicate" the problem because it hasn't had the problem for a few months now.
I registered my 2008 IS on Lexus Drivers site and found my service history. Nothing but small maintenances like alignment, squeaking brakes, and tune ups. But when I went to check the recall all I had listed for my IS was the "wiper arm nut" and "trunk release lever". Nothing about carbon build up.
#887
You don't need a letter, and.....
No, you don't need a letter. If you had misfire the codes will be stored.
I had my 2008 IS 250 in for the top end cleaning about 6 months ago. I would get the little idle
"rumble" about twice a month. I still get it even though I had the carbon cleaned.
I brought the car in for service this week and my SA called back to say that they did get the codes and they already got the okay from Lexus Corporate to replace pistons, etc. My car always ran perfectly fine except for the occasional "rumble". Hope they put it together okay and it runs as good as it used to.
I've only got 29,500 miles on it. A lot of short trips. That may have contributed to the carbon build up.
I did WOT about once a month. I guess it wasn't enough.
Cheers
mrjazz
Cheers
mrjazz
#889
Mr Jazz, which dealership did you take your car to, if you don't mind my asking?
Cheers
mrjazz
Cheers
mrjazz
#890
Jim Falk Lexus in Beverly Hills.
I've always been happy with this dealership. They are very thorough. Plus you alway get a loaner
car. I've got a 2013 IS 250 as a loaner. It's exactly like my 2008 only no Navigation. Looks. feels. and runs exactly the same. Too bad it's red!!!!!!!!!
#891
I had this service done at Lexus shortly after Christmas 2013. Seemed like a good thing... but now I have this tin foil noise coming from the engine. Or course, the dealer can't replicate the noise but they conveniently told me that I need to replace the transmission at $4k which is not covered under warranty (2007 IS250 with 95k miles). I have a call with Lexus Corporate because I've never had an issue with the transmission nor had this noise until after the ZLA service campaign was done.
Beware - just get a full disclosure from your dealer if you encounter any issues.
#892
I'd say time to get rid of it if they don't do anything to help you. The piston fix did nothing to fix the issue on my car. I'm under extended warranty, but I'm done with Lexus after the first fix needed like this. They should be ashamed of themselves for continuing to put out cars with this bad engine design and not truly fixing the ones on the road already.
#893
I've had my car to the dealer twice for the carbon buildup issue, but they couldn't replicate or get any codes so wouldn't perform the TSB. Any tips on how to get the codes to come up on my own? i'm also thinking about just having the top engine clean done, just because i know the buildup is a problem. Any idea what dealership charges for this?
#896
Very soon I suppose. I have the 2010 Is250 , 46500miles and i experienced yesterday for the first time a drop in rpm while at stop. No lights came on. the engine wanted to shut off almost. On the next stop was ok and ever since. Is this the sign on CPU?
#898
How many miles do you have? When was the first time you experience the issue? When and what miles did you get your repairs?
#899
I have 60k miles on my 09 is250 AWD. bought it with 30k, started noticing carbon around 45K. Car would run/rough almost stall when i almost came to stop. it was very intermittent, but very noticable. Just got car back today. So far so good.
#900
Thanks for the quick reply. I have 45k on my 2010 is250. Starting to get worried, but I'm glad it's on a 9 year/unlimited mile warranty. My main concern right now is the clutch and transmission. I have a six speed. Been reading about the clutch issue. I hope if it's happens, it happens soon. So I can still be in the drivetrain warranty.
