safe way of removing trunk spoiler held by 3m trap?
Old 09-28-12, 06:19 PM
WeisISF
WeisISF's Avatar
Default safe way of removing trunk spoiler held by 3m trap?
I am trying to remove my trunk spoiler that is held in place by 3m double sided, but i don't want to just try to pull it of due to being afraid that it would take some of the paint with it. will using a hair dryer to supply heat and fishing line do the trick? or are there better techniques out there to do the job?. Thanks in advance.
Old 09-28-12, 06:28 PM
Initial G
Initial G's Avatar
I would try using a heat gun and some floss. Heat the area for 15-20 miunutes or so. If its just an oem spoiler, it should not be that much 3m tape there or difficult. Good luck.
Old 09-28-12, 08:40 PM
VTsuckah
VTsuckah's Avatar
heat and fishing line is all you need.
Old 09-28-12, 08:49 PM
600rr05
600rr05's Avatar
+1 on the fishing line. Don't forget to use gloves though
Old 09-28-12, 10:55 PM
CLIS250
CLIS250's Avatar
just pulled mine off, came off with no issues. but if it doesnt wanna come off easily use some fishing line that stuff is strong.
Old 09-28-12, 11:02 PM
KillaIS250
KillaIS250's Avatar
Yeah don't just pull it off, heat it up and use the fishing line. It will come off easily. Then just clean up the left over tape
Old 09-29-12, 06:14 AM
chase350
chase350's Avatar
Floss works great.
Old 09-29-12, 07:09 AM
reyoasian
reyoasian's Avatar
I actually find it easier ripping off 3M when it's cold...
babiibryan
05-04-18 07:03 AM
poorkidlol
12-22-10 10:33 AM
Lexus@17
05-18-10 01:15 PM
sahara78
05-15-09 06:58 PM
EthanV
04-13-09 09:42 PM
Quick Reply: safe way of removing trunk spoiler held by 3m trap?
