balding tires, should I be concerned?
So I definitely need new front tires due to the balding on the outter edge of the tire, but this brings me to my question. Since just the outer edge of both the tires are balding, and not the inside edge (other side, inside the wheel well), Could this be an alignment issue? Or have most other IS owners had the same situation with tire wear?
Thanks.
Thanks.
![](http://i1164.photobucket.com/albums/q565/downtuned/IMAG0547.jpg)
Yup it's an alignment problem. Too much outer wear. There are members who have experienced the exact opposite which is inner wear.
You might want to put these bushings to replace the stock bushings too and get the car properly aligned.
https://www.clublexus.com/forums/is-...eo-inside.html
