IJDMtoys perfect fit interior LED who has them
IJDMtoys perfect fit interior LED who has them??? how do you install the front one because there like 3 bulb in there so do I just stick it in anyone?
Dome light, I assume that you got the one piece LED light. Remove the whole dome light unit, take out those three bulbs, and save one little black connector, came off from the bulb. Then remove the plastic cover and put ur LED light in from there, connect all the wires together, and lock back on the black connector. Make sure the light is working before put them all back. Good luck
I recommend you use the middle hole. Other two will still work but it doesn't last as long as the middle one, which I know you won't like it either. Oh! You might need some double sided-tape to hold on to the surface. You dOnt wanna the light lying on the plastic cover. But for me, I didn't use double sided tape becuz I found a way to fit tight in there, you can try too lol, but of course u don't want to break it. Enjoy on the modding
My pleasure
I recommend you use the middle hole. Other two will still work but it doesn't last as long as the middle one, which I know you won't like it either. Oh! You might need some double sided-tape to hold on to the surface. You dOnt wanna the light lying on the plastic cover. But for me, I didn't use double sided tape becuz I found a way to fit tight in there, you can try too lol, but of course u don't want to break it. Enjoy on the modding![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I mounted mine with double sided tape too because sometimes it rattled and it looked weird from seeing all the individual LEDs. Now that its mounted with doublesided tape, it looks nice and evenly output. Also, I recommend replacing the double sided tape on the rear one (if you got it) because the tape they provided didn't hold up very well for me.
FYI, I used some left over double sided 3m trim tape.
PS, thats what she said on the "do i just stick it anyone?"
