so to do the tire pressure sensors you need the #s which you pull with a different scanner right?
Yes. When I tested the tire section it gives you the option to select Main or 2nd. Once you select which one you would like to add, it gives you very detailed instructions about adding TPMS sensors. You have 300 seconds to add the sensors by serial number. Seeing as our system doesn't report which tire is low, it doesn't matter what serial number is where.
My winter tires are set to arrive in two weeks and I can take a video/screenshots to confirm.
I can if you can wait for another week (next Friday) because I am away for school and the cable's at home 250 miles away. I have another smart key card coming in next week to be programmed to the car, maybe I can sketch up a DIY by then.
this seems like the legit ****. I just want to custom some of my setting and I should be good!!! How much are people paying usually and whats the seller that people are recommending???
I have never in my life heard of such a negative video on youtube. That guy was horrible!!! he just picked and pulled apart the IS and complained about everything. It made him look like a fool for buying the car in the first place.
