Toyota Techstream and Cable for $35.(sorry no pirated software discussions allowed)
Old 10-08-12, 10:07 AM
pollvx
pollvx's Avatar
Default Toyota Techstream and Cable for $35.(sorry no pirated software discussions allowed)
For those who want to view trouble codes, check sensor data, update TPMS serial numbers, and adjust customization settings, this package is perfect.
MINI VCI for Toyota with Techstream
I received this in the mail after about two weeks and it works perfectly. The driver for the cable only works on 32-bit Windows systems. If you have a 64-bit version of Windows, you will either have to install Virtual Box with a 32-bit O/S or dual-boot.
This works great on my 2007 IS250 and Techstream has a selection for pre-2008, 2008-2011, and 2011+.
pollvx is offline
Old 10-08-12, 02:09 PM
sutekidane
sutekidane's Avatar
I bought one of these in Shenzhen last month for about $10 USD and it was bundled with the lastest software and drivers. I was able to disable DRL, add new (never been programmed) keys to the car, erase lost keys, and make adjustments to features that only dealer can work with.
sutekidane is offline
Old 10-08-12, 02:47 PM
nosurprise
nosurprise's Avatar
Where do you plug that into the car? If you can add keys, that would be cool ... I want to get one of those credit card keys.
nosurprise is online now
Old 10-08-12, 04:22 PM
nmpeter
nmpeter's Avatar
Damn I need this!
nmpeter is offline
Old 10-08-12, 04:48 PM
Quik208
Quik208's Avatar
Nice find!
Quik208 is offline
Old 10-08-12, 06:38 PM
NimaM
NimaM's Avatar
Wow, this is a must have item!
NimaM is offline
Old 10-08-12, 07:05 PM
jbounnoi
jbounnoi's Avatar
gonna give it a try!
jbounnoi is offline
Old 10-08-12, 07:11 PM
tedward88
tedward88's Avatar
I wonder if you can program used keys with this...
tedward88 is offline
Old 10-08-12, 07:32 PM
Snyperifle
Snyperifle's Avatar
Man I paid a dealership $33 to change a bunch of settings and ended up having to do most of it myself cause the tech had a hard time reading the screen. I could have just bought one of these...
Snyperifle is offline
Old 10-08-12, 10:29 PM
nosurprise
nosurprise's Avatar
I found this video where he demonstrate the tool and software; he said you have to use it with crack.
Old 10-08-12, 11:06 PM
sutekidane
sutekidane's Avatar
Yes it can, BUT there's a big catch to it. I asked the seller where I bought the cable the same question at purchase, they said once all the keys are wiped from the ECU you will need to provide a new seed # and passcode to the ECU for new rotation calculations. The code cannot be generated in TIS itself. You have two choices to obtain the code: (1) from Toyota/Lexus officially and (2) from a passcode keygen. Unfortunately the passcode keygen is dongle (hardware) protected, so it doesn't work without the hardware itself and costs roughly $200 USD.
I was able to program a new (never been programmed) smart card key to my IS350, though.
Old 10-08-12, 11:09 PM
smokyis350
smokyis350's Avatar
Can this read error codes?
smokyis350 is offline
Old 10-09-12, 09:02 AM
pollvx
pollvx's Avatar
Yes. It will display error codes by each ECU with details.
pollvx is offline
Old 10-09-12, 10:11 AM
B16da9
B16da9's Avatar
Could you post the steps to add a new key?
B16da9 is offline
Old 10-09-12, 10:17 AM
cyberscorp
cyberscorp's Avatar
Subscribed . . .
cyberscorp is offline
Quick Reply: Toyota Techstream and Cable for $35.(sorry no pirated software discussions allowed)
