Suspension crapping out covered by warranty? (Using aftermarket springs)
Reason is pretty obvious with any lowering springs installed onto STOCK shocks....
The shock is unable to compesate for the much HIGHER spring rate of a lower spring. Even though dealer replaces the shock, it will get blown again in pre-maturely.
The STOCK shock was desgined to work WITH THE STOCK springs.
I would get a better SHOCK like F-SPORT which is much stiffer to hnadle the higher spring rate. Or go coil-overs...
FOr sure question #1, is HELL NO. Dealer is going to deny the warranty big time. Question #2, dealer will deny it...for the common reason that I mentioned above. OEM springs weren't meant to handle higher spring rate of lowering springs. But you can get away with it because F-Sport advertises that you can use OEM spring.
#3 is unethical so I leave that topic up to you. It's warranty fraud
eyecue
02-24-16 07:35 PM
Expresso1
09-06-05 12:23 PM
