Routing Satellite Cable from Head unit to Trunk?
Does anyone have instructions or guidance how to route a cable from the head unit back to the trunk?
I'm installing the VAIS SL3s for satellite radio but want to use the sharkfin for the antenna and need to bring the cable back into the trunk to access it.
What's the best way to do this?
[QUOTE=JonVirgi;7547125]Does anyone have instructions or guidance how to route a cable from the head unit back to the trunk?
What's the best way to do this?[/QUOTE ic
I cheated and removed the the eh trunk panel and threaded it behind the upper seat rear reached in and pulled thru then routed it under the door sills along the carpet edge and up to the dash under the lower dash panel but it works great good luck]
skperformance
05-19-09 09:54 AM
