Will 19" x 8.5 +35 Offset 255/35/19 all around fit stock 08' is250 awd?
Hey club lexus,
I am being offered a set of used wheels and i would like to know if this set will fit without having to modify my ride. I am currently running STOCK everything.
2008 IS 250 AWD
Specs:
19" x 8.5
+35 Offset
I would like to know before i purchase them. Thanks in advance for all the help!
2008 IS 250 AWD
Specs:
19" x 8.5
+35 Offset
Thanks for the help guys.
If I change the front tires to 235/35/19 im sure it will clear the wheel well, but will it cause cause problems/damage to my car considering its AWD? I was told that staggered is not recommended on AWD from a tire shop. Thanks agian for the help guys, btw its my first lexus/car ever so please bear with me lol
For AWD, you will need to retain overall diameter to be the same (or as close as possible) between front and rear.
Best combo to achieve that is 225/35/19 (25.20" overall diameter) and 265/30/19 (25.25" overall diameter)
On the front, go with 225/35/19 and you will be about just fine. I have no problem with mine with the same wheel spec with 235/35/19.
On the rear, the wheel will sink too much inside the wheel well. Should better go with 9.5+35 in the rear and pair with 265/30/19 tire.
Sorry to bring this back from the dead. I have a 2012 is250 AWD and being offered 235 35 19 with 10 offset all around. Will this be safe on my AWD?? Does it meet the specs needed ??
allicedout
01-07-14 03:25 PM
