How to reset airbag light on 07 IS350?
Turning off the ignition will reset the light (it does on my 250). If it comes back when you turn it back on, the fault that triggered the light in the first place is still present.
You could also try disconnecting the battery for 10 min as this will also clear the codes on the airbag ECU.
SoufSidah
01-20-06 01:00 PM
