brake wear.... got a question about pads
Had the brakes inspected today and the fronts are at 9mm. Rears are at 8mm. Sorry for the dumb question, but what exactly does this mean as far as wear go?
Dang, that's surprising. I'm approaching 26k miles.
For the record, I manually shift to all my stops. Might have something to do with this excellent wear.
^Driving style does have alot to do with it. So you help the foot braking with exhaust braking using down-shifting. I've thought about this before, and its really brings up a valid point. Would you rather have increased wear on the clutch or the brake pads? Just something to think about.
Definitely a good point and worth a lot of thought. One thing I do avoid is downshifting into first (with the auto trans). That's where a lot of strain can be created. Overally, I keep the rmps down throughout the shift range, which I believe prevents less strain on everything.
in light of dumb questions--when my breaks start to give off a high pitched squeal when applied at low speeds or reversing.....time to change them out?
how much does it cost to get them inspected?
Alot of places charge nothing for a visual inspection, but they also assume that if you do indeed need brakes that you will get it taken care of that moment. So take it somewhere you'd like them to work on the car in case the brakes are gone.
GL!
Revived
02-26-17 07:01 PM
