Adding a 12" sub to my IS350
Ported straight to my ski hole. Its amazing how it sounds with the back seat arm rest up and then to hear it closed. I have a mesh screen put over the hole for looks.
Im currently rebuilding, ill take tons of pics and make a thread for all of you to marvel at. 370amp high output alt, 3 runs of 0awg, 4 shurikan bt100 batteries, my build will make steve meads build look like a child built it.. but to the OP.. that box looks legit for a single sub, port will blow up right threw where the stock 8" is, clean i like it. line outs are ok if your not looking for perfect bass response... that being said i use audio control lci8 as my converter. honestly ive heard an is350 with an audison bit1 and theres no difference in left to right or front to back response,the audio control is about an 1/8 of the cost as well. Any thoughts on what kind of woofer? i know your not trying to be to ridiculous just some sq bump. BUT if your not set on hugging jl's nuts like everyone els on this forum, you should check out some non-mainstream companies, sundown, skar, obsidian, cadence, DC, ect..
You seen my set up before but here it is again. Custom made and can get to my spare with no problem. The facing is card board with carpet wrapped on it and it fits so snug I can remove it and put it back in with no problem.It hits so hard through my ski port its unbelivable. People think i have 2 12's
WOW..
Probably way more bass than I need. But wow, very clean.
Not quite as good as the two 12" subways in the trunk. But very nice nonetheless.
no prob - happy to help. Here's my build thread if you are interested. Its with a ML system but it shows how to run cables etc.
https://www.clublexus.com/forums/is-...b-install.html
i have 09 is250 non Ml.im still confused after reading 15 pages.should i tapped in stock sub wires or front L and R front woofer?i never install any audio in m life.i have my old sub and amp in my first car.i will bring to the audio shop to swap them to my is.what should i tell audio installer to tapped in.Thank anyone can help
How hard does that system hit, I've never heard the output of a side mounted sub, i just hate how ridiciously priced the box's are,again for $350 thats a two rockford P3's
what do you mean by line outs are ok if im not lookig for perfect bass response? I been looking at a Alpine Type X around 1000 rms, got real good reviews and priced very well. That box is not only affordable, it looks super clean and that port no one will even know it exists but the best part is i will still have a trunk at the end of the day for other random crap.
