Another Stealership Story
Long story short, I have an 08 is350 that is under factory warranty for another 6 weeks. Recently I noticed excessive noise from front end and took the car in. Tech. found some suspension components loose, including sway bar bushings, rack and pinionon steering column and strut mounts. Everything seems right and tight and because car was under warranty no cost to me. NOW the theft. Dropped car off at 10 am S/A said would call at noon for update. S/A did not call so I called at 1 30 pm and got voicemail. S/A returned my call at 2 30pm stating tech had just put my car on the lift 20 minutes ago. S/A called at 4 00 pm stating car was ready. Arrive at 4 30 to pick car up sign paperwork drive home. Looking down at bottom of paperwork Stealership charges 6.5 hours of labor( the entire length of time the car was there)at $123 per hour for a total of $799.50 to be billed to corporate. At most the work done totaled 2 hrs., in reality probably 1 hr. In the end corp. passes those costs down to us consumers and we`re the ones taking it in the shorts.
Hard to say. I've come to learn over the decades that what a service advisor tells me or what's written on the invoice is not often what took place. I've watched my car get taken in, waited around, and seen when it's ready. Often I don't get told until 30 minutes to 2 hours later. Things don't always go on an exact schedule or communication between the techs and the advisor's office isn't always instant. Other times I've been told the techs tested something, but the invoice says something else. Or vice-versa. Things can get hectic, they type fast, or often use standard explanations to fill in the blanks. If things are in question or seem suspect, the best way to get to the bottom of it is to talk to the SA and ask specifics.
The dealership I go to never put amount for warranty work -- always put $0.
I think most of the time is not as simple as that. If they lose $100 dollar, they won't necessarily raise the price of the car by $100 to keep the margin at 4% (I just made those numbers up). It would depend on a lot of factors like cost, competition, market share, etc.
