MY 2nd DIY - intuitive parking assistant
This weekend I'm doing my 2nd DIY - intuitive parking assistant for IS250. Parts are original for IS250 bought in Europe and looking to integrate it with my IS250.
Need few answers:
- is it easy to take rear and back bumper off? Is is east to put it back ?
- by any chance bumpers have marking where to drill wholes ?
- is there any video / manual how to take bumpers on and off?
- do you think I will do everything in 1 day or I should split it in two days?
Need few answers:
well here's how to remove the bumper
but not sure how you are going to integrate Park Assist. The dummy button is easy, but how are you going to wire it to the navi to show on the screen? If the car does not have PA then it does not have the sensors nor does it have pre drilled. You'll either have to buy a new bumper with the PA holes or drill your own.
Nope. Because the park assist bumper and non park assist are 2 different bumpers. It's not like they took a regular bumper and drilled holes for it at the factory. I've seen the inside of non park assist bumpers. No markers. You could buy park assist pre painted bumpers from Sewell however. Search the forums. There was a guy wanting to do this a year ago, but not sure if he ever did.
Istarzan, every bumper even if it doesnt come with park assist has the marking of where the holes would be on a car with park assist. Just like every trunk, wether the car has navi or not, has the cutout marking for the reverse camera.
Bumpers are all made together and before they are even assigned to a vehicle. They are all made the same way. If it is assigned to a vehicle with park assist then they cut out the markings, if its not, then the bumper doesnt get cut however the marking will still be there.
Good luck.
Good luck.
Good luck.
Good luck.
I have seen two different ways of installing this. One is a European system that is standalone. The other way is to install all of the OEM parts and interface with the built in ECU
I wish you the best of luck. I was going to do this as well, but traded for a car that had it from the factory
not to be negative but if your worried about taking the bumpers off and mounting then its gonna be really hard...id be more worried about the wiring. Or are you simply just trying to install sensors so it looks like you have the option installed? I know someone on here did that which just seems like a big waste of cash but to each his own.
oldhate
10-22-11 08:59 AM
