I'm planning to remove resonator
Hello IS250 owners,
I'm planning to remove my IS250 resonator. It cost me $80 to remove it.
I have stock exhaust system, any recommendation for my plan ?
Is it okay to remove resonator ? (To engine system, and not passing emission test ?)
Thank you and have a great day !
Thank you, since I'm in GA, I should contact department.
So just remove stock midpipe and get aftermarket mid pipe ?
I just want some sound effect in my car
deleting your resonator only sounds good if you have at least an axle back to go with it, otherwise, like others said it will get raspy and not sound the greatest.
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
My HKS + Invidia setup sounds deeper at idle and WOT (compared to res delete) and had zero rasp.
Very true. I learned that the hard way. My stock midpipe with a deleted resonator is sitting in my garage collecting dust
Heres the thread I made comparing a few different exhaust setups that Ive had, including a resonator delete
https://www.clublexus.com/forums/per...ia-takeda.html
