All windows are not opening, except driver.
Old 11-03-12, 08:33 PM
Jake
Jake's Avatar
Default All windows are not opening, except driver.
I was 'attempting' to program my remote key to my memory (#1) position and I held the unlock button down for too long (I probably wasn't even doing it right.) Therefore, all the windows and sunroof rolled down, as designed. I put my car in the ON position and proceeded to roll up the windows. Only the driver side window would roll up, from the main drive side window switches. I went to each of the other window switches and tried the open/close function, nothing happened. I pulled the ETCS & EFI fuses several times. Still no luck. I went to a last ditch effort and took my physical key and put it into the key slot outside the car. I turned it to the left, and all of the windows and sunroof closed. Still, ALL of the window switches on the inside, except driver window up and down won't work. The battery has not been disconnected anytime recent. This happened to me three months ago. It lasted for a few days and then it started to work as designed, hasn't happened sense.
Has anyone else had, or heard of this problem before?
Old 11-04-12, 07:21 AM
ThreeFive0
ThreeFive0's Avatar
It sounds like the same problem when you disconnect your battery. Try searching for this in the forums, it has been discussed. I would help, but I wouldn't be able to tell you how clearly enough. I did something like, I held down my drivers side window switch on each window while I leaned over and pushed the respective door switch. Its was kinda like making them recognize the respective door's window. But like I said, just search for it and you will find more info than I can tell you at this moment.
Old 11-04-12, 07:54 AM
reyoasian
reyoasian's Avatar
Window lock...?
Old 11-04-12, 07:55 AM
ThreeFive0
ThreeFive0's Avatar
Originally Posted by reyoasian
Window lock...?
That would be hilarious! Easy fix though, buy a new car that doesn't have power windows! LOL!
Old 11-04-12, 08:09 AM
genaos11
genaos11's Avatar
Try hold passenger window switch dwn 4 10seconds and then push up on windowswitch to roll window up then hold it 4 10 second includin it rolled up and repeat rest back window should do the job I dnt knw if u tried that yet
Old 11-04-12, 09:17 AM
Jake
Jake's Avatar
The window lock is not on. The green LED's on each of the switches aren't even lit up, they don't blink either. The same applies to the main driver side switch. I'm about to go outside and try what ThreeFive0 has suggested.
Old 11-04-12, 09:51 AM
ThreeFive0
ThreeFive0's Avatar
Just keep playing with it. I forgot what exactly I did, but it eventually worked. Search "windows dont work after battery disconnect"
AE03
11-22-18 06:14 PM
zorzside
04-29-18 10:27 AM
guamgirl
RX - 3rd Gen (2010-2015)
04-18-18 06:25 AM
snayger
05-24-13 12:26 PM
Lexminster
01-16-11 09:01 PM
Quick Reply: All windows are not opening, except driver.
