soon to be IS350 owner...if everything checks out
First off, I would like to thank everyone on this forum for their contribution. I've learned a great deal about this vehicle and found the guide Buyer's Guide to Used Lexus 2nd Gen IS Models (merged buying advise threads) to be very helpful providing great insight into what to look for when purchasing a used IS350. I am very excited to own this car if everything checks out.
The vehicle I am considering is a 2007 IS350 with 55k miles. I've looked over the service record and didn't see any obvious alarms. If you see anything that I should be concern about, please let me know. Thank you in advance.
SERVICE TYPE DATE SERVICE PROVIDER MILEAGE REPAIR # DESCRIPTION
Dealer Reported 02/25/2012 Pohanka Lexus of Chantilly 51901 0568959 VIRGINIA STATE INSPECTION
Dealer Reported 02/25/2012 Pohanka Lexus of Chantilly 51901 0568959 INSTALLED FEASTENERS FOR LF WHEEL WELL
Dealer Reported 02/25/2012 Pohanka Lexus of Chantilly 51901 0568959 CUSTOMER REQUESTED ENGINE COVER LEFT UNINSTALLED.
Dealer Reported 02/25/2012 Pohanka Lexus of Chantilly 51901 0568959 CUSTOMER IS AWARE OF UNINSTALLED DUST COVERS
Dealer Reported 02/25/2012 Pohanka Lexus of Chantilly 51901 0568959 COURTESY CAR FUEL AND CLEANING CHARGE IS $5.00 PER DAY
Dealer Reported 02/25/2012 Pohanka Lexus of Chantilly 51901 0568959 CUSTOMER REQUEST ENGINE COVER UNINSTALLED
Dealer Reported 02/20/2012 Pohanka Lexus of Chantilly 51752 0568358 REJECTED DUE TO DIFFERENT HGIH BEAM BULB
Dealer Reported 02/20/2012 Pohanka Lexus of Chantilly 51751 0568006 RECOMMEND REPLACEMENT OF THE LEFT HEADLIGHT ASSEMBLY INCLUDING THE ECU AND COVER
Dealer Reported 02/20/2012 Pohanka Lexus of Chantilly 51751 0568006 COURTESY CAR FUEL AND CLEANING CHARGE IS $5.00 PER DAY
Dealer Reported 02/20/2012 Pohanka Lexus of Chantilly 51751 0568006 REPLACED BULB
Dealer Reported 10/16/2011 Pohanka Lexus of Chantilly 49021 0546036 NO ABNORMAL CONDITIONS FOUND AT THIS TIME.
Dealer Reported 10/16/2011 Pohanka Lexus of Chantilly 49021 0546036 INITIALIZED MOONROOF NO ABNORMAL CONDITIONS FOUND AT THIS TIME.
Dealer Reported 10/16/2011 Pohanka Lexus of Chantilly 49021 0546036 COURTESY CAR FUEL AND CLEANING CHARGE IS $5.00 PER DAY
Dealer Reported 10/16/2011 Pohanka Lexus of Chantilly 49021 0546036 THANK YOU FOR YOUR BUSINESS.
Dealer Reported 04/02/2011 Pohanka Lexus of Chantilly 44254 0510308 TECH HAS INSPECTED VEHICLE THROUGHLY AND FOUND EVERYTHING OK AT THIS TIME NO ISS
Dealer Reported 04/02/2011 Pohanka Lexus of Chantilly 44254 0510308 COURTESY CAR FUEL AND CLEANING CHARGE IS $5.00 PER DAY
Dealer Reported 04/02/2011 Pohanka Lexus of Chantilly 44254 0510308 THANK YOU FOR YOUR BUSINESS
Dealer Reported 04/02/2011 Pohanka Lexus of Chantilly 44254 0510308 COMB: OPPOSITE SIDE
Dealer Reported 03/26/2011 Pohanka Lexus of Chantilly 44076 0509099 HAD TO REPOSTION AFTERMARKET WIRES UNDER DASH THAT WERE RUBBING ON STEERING COLU
Dealer Reported 03/25/2011 Pohanka Lexus of Chantilly 44023 0508792 TECH FOUND OUT THAT WIRES ARE AFTER MARKET AND MAY HAVE CUT WIRE TO THE KICK PAN
Dealer Reported 03/25/2011 Pohanka Lexus of Chantilly 44023 0508792 THANK YOU FOR YOUR BUSINESS
Dealer Reported 03/25/2011 Pohanka Lexus of Chantilly 44023 0508792 COURTESY CAR FUEL AND CLEANING CHARGE IS $5.00 PER DAY
Dealer Reported 03/25/2011 Pohanka Lexus of Chantilly 44023 0508792 BLA REPL FUEL PRESSURE SENSR GASKET AND TIGHTEN - IS/GS
Dealer Reported 03/25/2011 Pohanka Lexus of Chantilly 44023 0508792 ALE REPL COMP SPRINGS & LASH ADJUSTERS FOR IS 350
Dealer Reported 03/25/2011 Pohanka Lexus of Chantilly 44023 0508792 9LG REPL PEDAL PAD, REFLASH, AWFM - IS MODELS ONLY
Dealer Reported 03/05/2010 Wilkie Lexus 31211 0191160 REPLACE DRAIN PLUG GASKET
Dealer Reported 03/05/2010 Wilkie Lexus 31211 0191160 OTHERS
Dealer Reported 01/20/2010 Wilkie Lexus 29641 0187729 SET AND ADJUST TIRE PRESSURE
Dealer Reported 01/20/2010 Wilkie Lexus 29641 0187729 CHANGE OIL AND FILTER, CHECK ALL FLUIDS, SET TIRE PRESSURES
Dealer Reported 01/20/2010 Wilkie Lexus 29641 0187729 REPLACE FRONT ROTORS
Dealer Reported 01/20/2010 Wilkie Lexus 29641 0187729 F. DSC BRK PAD
Dealer Reported 07/03/2009 Wilkie Lexus 23859 0171465 PERFORMED EMISSIONS TEST,NEED 2 TIRES FOR INSPECTION,CUST DECLINED AT THIS TIME
Dealer Reported 07/03/2009 Wilkie Lexus 23859 0171465 CHANGE OIL AND FILTER AND CHECK ALL FLUIDS
Dealer Reported 07/03/2009 Wilkie Lexus 23859 0171465 9LA REPLACE FUEL DELIVERY PIPES FOR IS250/350
Dealer Reported 07/03/2009 Wilkie Lexus 23859 0171465 REPAIR OTHERS-
Dealer Reported 12/11/2008 Wilkie Lexus 18645 0156602 CHANGE OIL AND FILTER AND CHECK ALL FLUIDS
Dealer Reported 12/11/2008 Wilkie Lexus 18645 0156602 COULD NOT VERIFY SQL AT THIS TIME,PULLED WHEELS AND CHECKED BRAKES,7/32F,10/32R,
Dealer Reported 12/11/2008 Wilkie Lexus 18645 0156602 TEST DROVE CAR WITH SCAN TOOL,NO CODES PRESENT,CAR OPERATING AS DESIGNED AT THIS
Dealer Reported 06/12/2008 Wilkie Lexus 12660 0141863 10,000 MILE SERVICE **RESET """"MAINTENANCE REQ'D"""" LIGHT**
Dealer Reported 06/12/2008 Wilkie Lexus 12660 0141863 JUNE STATE INSPECTION AND EMISSIONS
Dealer Reported 06/12/2008 Wilkie Lexus 12660 0141863 OTHER OPERATION
Dealer Reported 01/24/2008 Wilkie Lexus 6342 0131087 PLEASE RETURN THE RENTAL VEHICLE AS SOON AS YOUR VEHICLE IS COMPLETED OR A $55 C
Dealer Reported 01/24/2008 Wilkie Lexus 6342 0131087 5,000 MILE SERVICE **RESET """"MAINTENANCE REQ'D"""" LIGHT**
Dealer Reported 07/19/2007 Wilkie Lexus 9 0116624 PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
Dealer Reported 07/19/2007 Wilkie Lexus 9 0116624 JULY STATE INSPECION AND EMISSIONS
http://secure.drivers.lexus.com/lexu...ews_2011_01_31
Seems good. My lexus had so much stuff replaced by previous owners at dealers. But she still a beaut and runs great at 97k knock on wood!
it all depends on the price.
RopePusher
11-29-17 09:10 PM
