Battery brands?
90% of all batteries sold in the US are made by the exact same company and are THE EXACT SAME BATTERY but sold under different branding. Johnson Controls, Inc. Do some googling and you'll see!
Sears DieHard, Autozone, WalMart, almost all OEM batteries, etc.. they're all the same battery.
The cheapest source to date seems to be WalMart. Go get the right size, 72 month battery for your vehicle and you'll be set. Don't pay a dime more just because there's a different sticker on it!
Costco has a limited selection, and doesn't carry the proper Group 24 size. They try to make a Group 25 or 35 fit, I forget which.
I replaced the batteries in my wife's ES and my F last week. I looked at the ratings in Consumer Reports and decided on Bosch Premium Power, a Group 24F for her and a Group 24 for me (the polarity is different) Pep Boys carries Bosch, and I was able to negotiate them down to $93.00 ea. with return of the old core. I keep a couple to spent batteries in my garage so I don't have to go through the hassle of removing, then buying a battery and returning home to install it. I get dirty just once
Anyway, the Bosch's both fit fine and are working great with the both engines spinning quickly on startup. The warranty is 36 months exchange and 96 month prorated.
From my research It appears that the Bosch batteries are made by Exide.
Lou
Lou
Lol.. look again. Bosch is made by Johnson Controls. Pretty much the only battery that isn't is an Exide or "Duracell" car batteries which is just a borrowed logo to put over an East Penn battery.. which is junk.
I'm telling you. Just go to WalMart and get the 72 month correct series. They're all the same.
Lou
Lou
The IS uses a Japanese size battery, which is a different size to most Domestic and Euro sizes. My experience has been that the battery cross-reference lists do not list the correct replacement battery for the IS.
Mine came with a D26L size battery (the OEM battery was a Panasonic 80D26-L). So, I was able to match a battery to the exact specs. That said, before I bought, I went to all the local battery and parts shops, with the battery part number - most refused to sell the battery, as it "will not fit a lexus", the others didn't have one in stock, and instead recommended a battery that was too large, and by my measurements would have no chance of fitting.
I ended up getting a battery online, and fitted it myself. Even though the web site put big flashing warnings up on my order that it was not compatible with my car; the battery was a perfect fit.
There is another caution that you should be aware of; the stock battery is a standard Japanese Maintenance free calcium-silver battery. This type of battery is electrically slightly different from a regular car battery or an AGM battery. The lexus charging system, like most Japanese cars, is tuned for this precise type of battery chemistry, and replacing the battery with a generic battery will give reduced charging performance and shortened battery life.
The battery I selected, a "Varta Asia Dynamic" not only exactly fits the special Japanese size, but is also built with the same calcium-silver formula as the OEM battery.
Keep it simple .... go to Autozone, walk a few steps to the front door, go over to the battery display, look on the top row, and get a Gold Top 24-DLG, it's $110 with exchange. Done. Fits perfectly in the battery case even with the convenient carrying handle attached, and there are thousands of Autozones all over the country in case it fails. We travel a lot and that is important to us. Sure, you can to to Walmart and maybe save a few bucks, but then you have to schlep in there and deal with the dolts, it's not worth the few bucks you'll save over the life of the battery. Don't complicate your life.
As far as not charging properly, it's a wet cell 12 volt storage battery, it will work just fine with our charging systems.
Lou
