is250 tire pressure light
It seems like the weather had an effect on the change in the tire pressure of my car..Does anyone know of a good tire pressure tool that they can advise me in buying ? thanks in advance
also if you don't mind telling the standard amount of psi that the 250 run would be cool
thanks!
thanks!
if you have no aftermarket wheels/tires, it should say the recommended tire pressure on the inside of the drivers door. also, with temperature air expands (when its hot) and deflates (when its cold) sometimes if its cold outside and your car has been sitting awhile, the light will be on. but after a few minutes of driving the tires warm up and so does the air in the tire, thus expanding and light could turn off.
Long story short, the recommended pressure is on the inside of the driver's door. and to check the air pressure go to any pepboys, or even a gas station and buy an air pressure gauge for like 5 bucks or less.
quadocox
01-09-08 12:56 PM
