gf is250 started shaking check engine light blinking
Old 12-01-12, 03:01 PM
roc
roc's Avatar
Default gf is250 started shaking check engine light blinking
car has approx 90k,purchased new in 06,took the car to lexus and the servive writer explained that the car has a random missfire on cylinder 6,he said that the piston rings need to be replaced,car does not smoke or burn oil,on the way to the dealership car ran fine, the car has extended warranty and it will be covered.cl what is your take on this
Old 12-01-12, 03:09 PM
bob4256
bob4256's Avatar
Sounds like its carbon build up. There are already various threads on this already.
A simple search would have brought up these threads
https://www.clublexus.com/forums/is-...d-threads.html
https://www.clublexus.com/forums/is-...ld-up-csp.html
Old 12-01-12, 03:14 PM
roc
roc's Avatar
top end carbon cleaning was done approx 20k ago
Old 12-01-12, 06:27 PM
moses0324
moses0324's Avatar
I Just received a letter from Lexus stating that they would repair or fix this issue on any 06-10 is model. Even if it were out of warranty. I will try to scan
Old 12-01-12, 06:41 PM
bob4256
bob4256's Avatar
Be sure to share that here
Old 12-01-12, 07:30 PM
edgeucated
edgeucated's Avatar
it can come back w/in 20k, that's why lexus extended the warranty for the 250s carbon deposit.
Old 12-01-12, 07:38 PM
TheRusski
TheRusski's Avatar
Drive it hard....seems like it fixed my problem
Old 12-02-12, 10:59 AM
weenstan
weenstan's Avatar
Free fix regardless of extended warranty or not. SB is out for it. I had mine cleaned like 3 times and I'm only at 61k miles (2006 as well). When it gets bad again I'm going to do the piston ring fix. I drive pretty hard though so its taking awhile for the problem to come back.
rogers2
01-24-17 01:12 PM
CassieB
12-17-16 11:30 AM
Aguilar231
08-28-15 12:30 PM
RPH74
07-15-14 02:05 PM
Dstockton
Performance
12-11-11 07:00 PM
Quick Reply: gf is250 started shaking check engine light blinking
