hid bulb
exiakira: I'm biased but these Philips T10 194 bulbs have been super popular.
bob4256: Hope you're doing well!
Steve
Steve
i had swap my bulbs, and i found out my bulbs are two different brands , 1 is phillip and the other one is harison(the bulb that dealer had change it for free 2 years ago still under warranty), also the phillip bulb is dimmer than the harison. But the strange thing is the phillip keeps on which it was auto off sometime. any idea about this ?
exiakira: I would suggest swapping your bulbs left to right to see if the bulb is the culprit before spending any money as you want to make sure the problem is the bulb and not the ballast.
Here is a year old thread about the XenonDepot D4S bulbs if you are interested:
https://www.clublexus.com/forums/lig...ount-code.html
This particular member reviewed the 5000k color temperature as he wanted to get a little more color out of his stock bulbs but still maintain a lot of useable light output.
Coupon code CLGB08 upon checkout gets you a $20 discount per bulb.
Steve
Steve
Steve
Steve
I tried ordering some bulbs and it states the coupon code is not valid. Is there a new coupon code?
i just had the same issue 2 days ago. i got home and the passenger side headlight was off. i turned off the lights and on and the problem was solved. but i did notice a difference in color with the two bulbs. do you think the dealer will look at it and just replace the bulb for me? and can i ask them to replace both of them? i have CPO and going to the dealer on tuesday for the CSP
mwaull
06-02-06 10:17 AM
