Did u check if it comes with the harness ? on the LED ? my came only with one so i had to called local lexus and luckily they had the last one instock so i went and picked up. Have to call Sewell tomorrow to send me that missing harness.
this is the harness
It came with that harness but the cover is white not black, is there 2 different kind of harness?
The driver side came with black cover harness and driver side led works good.. Would it be possible that they sent me a non retro harness?
no the white cover is not the harness that the other side. I think Sewell messed up big time forgetting to ship with both harnesses but only shipped with one.
did you wired from right side to driver side and then another wired to the power ? if u did check all the wired and clamps correctly. U can test by just put the wired both headlight by touch the battery see if they can light up and then continues the work.
check wiring on both lights and make sure they match, also smell inside the LED board make sure it doesn't smell burnt, try the wire harness from the working side on the non working side and see if it comes on...if it doesn't then it's probably the lights and then at that point contact Sewell
