help isf front conversion
the OEM isf bumper will bolt on but require molding to fit correctly, its slightly wider than the normal 2IS. If you are referring to the ISF style kit on ebay (optionracing), it is a direct bolt on.
A search will yield these answers along with the differences between each
I'm in progress of getting all the parts together to do a full ISF conversion including the fenders, bumper, and side rocker panels. I would like to know if anyone on here has done it yet.
paulo is the only person I'm aware of that has done an almost complete IS F setup.
https://www.clublexus.com/forums/is-...n-to-is-f.html
https://www.clublexus.com/forums/is-...w-updated.html
Jeff
Jeff
