Brake Wear Sensors?
My '06 IS350 doesn't have electronic wear sensors. I've changed front and rear, and can say that for sure. Yep! If you are referring to the metal tab that hangs off of the brakes, for the purpose of scraping the rotor just prior to the friction material being depleted (as Gville350 has referred to in the post above), I honestly don't remember but can take a look. I don't think so, but most do have them to be honest. Can you be more specific as to what type of wear sensor you are referring to?
EDIT: Unless by "sensors", you mean some kind of electrical sensor that gives you a notification on the dash or something. I'm just talking about audible wear indicators.
I'm confirming that yes, one OEM brake pad out of a set of two for each wheel will have a metal tang. I kept the OEM rear rotors and OEM rear pads from my recent upgrade to PowerSlot slotted rotors and Axxis Ultimate pads, and just checked to confirm this. I would only assume that the fronts would be the same.
I wonder why only one tang per set, knowing that pads can wear unevenly from one side of the caliper to the other? Oh well, my Axxis pads have one on each pad.
don't mean to thread jack, but since we are on this subject
my brakes have been making a horrible screeching noise upon start up or initial braking, and then it goes away. I have always assume it was just scraping off the outer oxidation layers that causes this screeching, but could it be my wear indicator?
If it were the wear indicator, would it continue to make this noise every time i apply the brakes, or just the first couple initial times i apply the brakes?
